1JZ - Cannot Rev Pass 3000 RPMS - Need Guru.
#112
Speaking of the low oil light, I remeber when I was having the cut it was always on after I started the car, after I swapped out the harness to a harness that suited my car basically 5 speed soarer harness to 5 speed sc300. The low oil light went away and so did the cut.
But it is 100% something to do with a signal reaching the ECU telling the car, it has cranked succesfully and its running. Its not your cam sensor, its not your crank sensor and its not your knock sensor.
Good luck finding the right wire.
#113
re:
I did go and check the grounding on the knock sensors, as well as the resistance on the crank and cam sensors and their wiring. but that was long ago, so it is nice to know it's not them(i STILL had my doubts).
so body plug that mentions being running.
All i see at the moment is a starter signal, but that throws a ecu code...
i'm stuck working with the volume 1 book, so i'll do better when in a few days when I can look in the voume 2.
#114
due to the way the wiring diagrams work, i'm still SOL.
Without knowing which junction number and plug it is, I'm going to be lost in these pages.
I do think it's either IJ1 or IK1, but not 100%...going to look through pics in here to try and tell which for sure
edit: from pics it appears to be IK1.
Trying to find IK1's relation to engine, etc.
nothing simple(maybe overlooked).
going to try looking at Volume 1 tomorrow to use the "starter" section.
#120
so when i did my swap i was having the same problem.. when u say its doesn't rev pass 4k.. when u throttle it does it just stop?? because the problem with mine was.. the wastegate wasn't opening up and the ecu was stoppign the car from reving pass 4k.. if i were u .. make sure all ur vacuum lines are in the right place
LoveSCs
Performance & Maintenance
19
10-11-14 03:59 PM
