SC470TT will be Alive shortly!
Old 04-06-08, 03:54 PM
  #151
Lextreme
Lextreme's Avatar
Originally Posted by c0wboy
The th400 will fit with the GM bellhousing, but there's a TON of hammering on the underside that will need to be done. I foresee a 5lb maul in your future. Who built the Th400, or is it a stock unit? Looking like some good progress.
Eric
Really? Have you done a SC400 with TH400? You sounds like you really know this swap from inside and out.
Old 04-06-08, 05:35 PM
  #152
c0wboy
Banned
c0wboy's Avatar
I've just wrapped up the SP400 install on my MKIV Supra 4.7LTT so it's very much alike. The difference is that I used the Toyota bellhousing and mated it to the '400 by way of the kit. The driveshaft mates up perfectly, the length is perfect, and the trans mates directly to the rear of the motor. A couple of hammer strikes were needed to clear the shifter linkage, but that's about it.
With the straight uncut '400 using the adapter you're have, you're going to have to clearance [deform] the tunnel big time. That bellhousing is huge. One thing that was a pain was the ratchet shifter. The shifter is rather large and the dash support had to be "modded" to fit. If it helps I can take a few pics of the install so you see what I'm talking about.
Eric
Old 04-06-08, 05:45 PM
  #153
Lextreme
Lextreme's Avatar
so it's very much alike. Eric
When you assume, you make an *** out of you and me. just ins I installed the tranny without a single hammer. So I am not sure where you get TON of Hammer come in.
Old 04-06-08, 05:52 PM
  #154
c0wboy
Banned
c0wboy's Avatar
Can you take a pic? It's something I'd be interested in seeing. Did you have to clearance for the shift linkage? Every Supra I've seen with the Th400 bellhousing has had to be clearanced, and the SC is for our purposes virtually dentical to the Supra in terms of underside. That's my basis.
Eric
Old 04-06-08, 06:00 PM
  #155
RX469
RX469's Avatar
Very nice. Subscribed.
Old 04-07-08, 06:52 PM
  #156
Lextreme
Lextreme's Avatar
Got some updates. I managed to install the TH400 transmission into the SC400 tunnel without any HAMMERING. I got my driveshaft marked and will take it to a local driveshaft shop to weld and balance it. I also have a chance to make a custom plate for the transmission support mount with the stock SC400 support beam.
I spent few hours working on the turbo mid pipe and little of the down pipes. However, I spent most of my time finishing the intercooling piping. The pipes fit very nicely and look fantastic.
Old 04-07-08, 07:02 PM
  #157
twizted
twizted's Avatar
Oh snap! lol
Old 04-07-08, 07:03 PM
  #158
c0wboy
Banned
c0wboy's Avatar
Red X's man
Edit: I got most of them open. Can you take some underside shots of the tranny area specifically around the bellhousing and shifter linkage?
Thanks!
Eric
Old 04-07-08, 08:49 PM
  #159
1siksc
1siksc's Avatar
now that is pretty!
Old 04-07-08, 09:16 PM
  #160
Lextreme
Lextreme's Avatar
Not sure why pictures didnt show up....
Old 04-07-08, 09:21 PM
  #161
Lextreme
Lextreme's Avatar
Another picture
Old 04-07-08, 09:23 PM
  #162
Lextreme
Lextreme's Avatar
Another...
Old 04-07-08, 09:25 PM
  #163
Lextreme
Lextreme's Avatar
Few more.. but unable to attach more than one picture at a time
Old 04-07-08, 09:37 PM
  #164
97RSPSCTT
97RSPSCTT's Avatar
man i really admire the extremly hard work and insane fab work you have done, you are trully an inspiration for ALL, 6 or 8 cylinders. i wish you the best of luck on this ground breaking project.
Old 04-07-08, 10:12 PM
  #165
Lextreme
Lextreme's Avatar
Thanks for the nice words. I am waiting for two 4" 90 couplers for the turbo air inlets. These two couplers will route out and get fresh air. The 4" long leg couplers are hard to find. However, when it is done they will look very nice plus cool air from frog light area. I will need to drill the wall to reach out. That is why my turbos are position that way. The whole goal of this plumping is to get fresh air and keep it cool for the engine. Even with the inlet throttle body pipe. I would route it around and away from heat. Why heat up cool air again? That doesn't make sense.
Quick Reply: SC470TT will be Alive shortly!
