SC470TT will be Alive shortly!
#77
Anyway, for an average setup I think pair TO4E would be more then enough. The reason I choose .48 A/R is because I want good lower end and responsiveness along with hugh power at high end.
Here is some update:
I just recieve a set of MLS gaskets courtesy of Cometic Gasket. I also upgraded the head studs from 10mm to 7/16" (almost same size as 11mm).. The below pictures say it all.
#79
Nice choice for a turbo. The .48AR isn't gona be laggy at all.. but since you've got 4.7 liters and 8 cylinders pushing those bad boys, you'll have a pretty sweet top end pull too
Cometic head gasket- nice choice. That's who I bought my 2.5mm head gasket from to lower my compression too.
Awersome work !
Awersome work !
#84
Man, an N/A 4.7 with big valves and a mildly reworked camshaft would be gnarly enough to brag on-- Nice work on all of this-- it's a lot of work but totally worth it in the end-- if there was really an end.....
#85
Here is a little update. Got the heads back last week and took few days off with my family and back to work the day I got home. Here is my progress:
Ported heads, bigger valves, stronger springs and Lextreme Stage II cams:
7/16" ARP Studs, Cometic head gaskets:
The car was dropped off yesterday and the engine is officially out and parts are being transfer to the new 4.7 Liter longblock. The engine should be able to fire up by tomorrow afternoon, but I might not have videos until Monday. Here is the engine being taken out.
Getting closer and getting nervous too. It is the first SC400 with a Tundra block.
#87
Hey Scott,
I am loosing sleep over this also. It has been a long journey and it not going to end anytime soon.
After the engine fire up and run properly without issues then I will convert to electric fans, relocate the alternator and delete the AC. After that is done and no major errors, then twin turbo installation.
Sorry, I dont get notification when someone post.
#88
This is coming along quite nicely, man! Can't wait to hear her in a fly-by video that you owe all of us for this torturous wait Hope everything goes smooth from here on
#90
Wel Dave, you're getting there....Long journey, but your persistence pays off. Nice head work, and I like the extra sizing...Can't wait to hear this baby when you start it up and run it...Looking forward to the updates.
Ryan
Ryan
