Heater Only Work When Drive
Old 10-25-07, 08:19 AM
vugoodoll
vugoodoll's Avatar
Default Heater Only Work When Drive
Hey guys,
My car heater only blow heat when the car is moving, when I stop at red light then it start blowing cold air instead of heat. This happen also as well when the car idle in (P), then when I give some rev then heat start coming out. Please help me trouble shoot this.
Thanks for all your input.
95 SC400
Old 10-25-07, 08:31 AM
ChronoJ1
ChronoJ1's Avatar
Mine does the same. I'm just too lazy to fix it.
In any case, it is most likely your heater servo or clogged hose
If not, but very unlikely... it could be your water pump slowly going out.
Old 10-25-07, 09:19 AM
HELLAFLUSH
HELLAFLUSH's Avatar
Its probably the heater valve.
Old 10-25-07, 09:26 AM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
(1) moved to proper forum
(2) top off your coolant.
Old 10-25-07, 10:33 AM
mkorsu
Zombie Slayer
mkorsu's Avatar
I got $20 on this answer.
Old 10-26-07, 01:24 PM
vugoodoll
vugoodoll's Avatar
Ok guys, thanks for all your input. I check the coolant and it full. When the engine is on the coolant tank suppose to be empty on lexus? I know on Honda the coolant in the over flow tank just stay where it is but on lexus all the coolant been suck out of the tank?
Old 10-26-07, 01:36 PM
mkorsu
Zombie Slayer
mkorsu's Avatar
Nope. You sound low. Burp the system, probably air in the system.
Old 11-07-07, 06:16 PM
sc400injen
sc400injen's Avatar
anybody have the heater totally go out? my gauge says max hot and blows no air on auto but i can increase the fan speed but it is cold air, almost sounds like a control module, any help would be greatly appreciated
Old 11-07-07, 06:18 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
^^ search "heater core control valve" or variants of.......
If I had a dollar for every time someone said "my coolant is full" when their heater didn't work I'd be rich. TOP IT OFF. "make it rain"
Old 11-07-07, 06:24 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Lemme show everyone this biichen little search engine we got in this here establishment........ This outta turn your grey skies blue...........
https://www.clublexus.com/forums/sho...nt+heater+full
Old 11-08-07, 10:14 AM
Curry
Curry's Avatar
^ Thanks OLT
Did it earlier in the morning and my heater is working just fine now.
Old 11-08-07, 04:46 PM
slappy96
slappy96's Avatar
Default OLT= Funny
Subtle...
Old 11-08-07, 08:04 PM
TRD_Power
TRD_Power's Avatar
I had the same problem and did an entire radiator flush, topped it off with new coolant, and POOF! Like new.
Old 03-26-08, 04:02 PM
sc400injen
sc400injen's Avatar
**** i know it's late but preciate it yall
-Knowledge
HRoscar
IS F (2008-2014)
21
10-18-18 01:38 PM
Tantrix
01-20-17 05:41 PM
JamesB94
01-12-15 10:21 PM
Session101
SC- 1st Gen (1992-2000)
12-06-13 02:48 PM
DaizenLex
03-25-04 10:19 PM
Quick Reply: Heater Only Work When Drive
