Air filter question
I've been doing a little reading on how to improve my gas milage since its horrible right now (sc400). Last I checked I was getting 12mpg and thats driving like a granny. It was mixed driving a little city a little highway.
Anyway I came up with a short list of things to check after searching around the forums:
Spark Plugs
Distributors
Fuel Filter
Seafoam
Seafoam Gas Tank
Air Filter
Check O2 Sensors
Synthetic Oil
New cat converter or catback exhuast (saving this for when i drop the turbo in)
Tune the emanage =P
Spark Plug Wires
Should I follow the DIY and do the BFI or would it be better to rip out the air box and slap on one of those 3 inch cone looking filters?
Spark Plugs
Distributors
Fuel Filter
Seafoam
Seafoam Gas Tank
Air Filter
Check O2 Sensors
Synthetic Oil
Tune the emanage =P
Spark Plug Wires
Thanks for the tips guys.
I guess for now I'll work on the BFI.
Should I invest in the K&N drop in filter or get the OEM filter?
I'm eventually going to lose the box when I go turbo... unless... I wonder if it makes a difference... using the BFI with the turbo... ?
OEM filter is fine. There have been stories where the k&n oil gets into the maf causing malfunction. I believe it happens when people re-oil it. Haven't found a definite answer because some people say it does and some say it doesn't.
Also keep in my if you seafoam, change the spark plugs after and not before you seafoam.
Its got about 181k. Runs great overall minus the gas milage.
My plan was to give it the tune up once I started working on the turbo since I wasn't driving the car much BUT I ended up having to do more driving so now I'm going to tune it up.
A friend mentioned that to me also about the cat being a potential problem. I plan to change that as well once I get the routine maintainence done.
I've got a highflow cat here from magnaflow, not sure if it will work or not, its got a 2.5 inch inlet and outlet.
Don't worry the fuel filter is next on my list right now. I was busy doing brakes and rotors this week.
so far droveabout 60 miles.. no prob so far
You can always do the "car wash cat" Go drive your car for a bit, get it nice and warm, then go to a car wash, shut off the car, and start spraying water in it until the water starts gushing out. Then rev it up till all the water comes out, there will be some left in there, my car was smoking so water the next morning, and after that all gone.
I did it on most of my cars, because we can't pass inspection (or get a lot of hassling) with aftermarket cats. Works well for me anyway.
It's funny because I just bought some tune up stuff too, not all of it, but a good amount. I went ahead and bought a cone w/maf adapter, seafoam, and new plugs. I need to get paid again so I can do caps, wires, and oil change.
What about the tranny? I couldn't find what kind of ATF that it needs, and BTW seafoam makes this new tranny stuff too. Saw it at my auto parts store.
K&N filters are good but yes the oil can get on the MAF and cause it to Malfucntion, this happened to my mom's explorer and friends tundra. I had a K&N filter on my last car, but I'm NOT putting one on the SC400 because of this issue. I heard the MAF on our cars is like $1000. The OEM Toyota filter is really good.
It says in your sig that you are going Turbo soon. If you are doing this really SOON, there is no real to point to making a BFI or cold air intake. Turbo Motors don't benefit from Cold Air intakes, cause the air gets really hot again when it passes through the turbo compressor. A big intercooler would a make a difference though
Yea ill stick with the OEM filter and call it a day. My tune up stuff is on the way.
For now im just going to re-do my exhaust 2 inch with a new highflow cat and dual magnaflows. No resonators.
I don't know how soon i'll be doing the turbo so I'll do the BFI.
When turbo time does come all I will have to do is cut the exhaust and just attach the downpipe. No big deal.
So new exhaust here i come!
