92 sc400 idle problems
Old 10-29-07, 04:30 AM
safbrx7
safbrx7's Avatar
Default 92 sc400 idle problems
i own a 92 sc400 w/ about 196,XXX miles on it. The only thing wrong with the car is that it idles really low. After the car warms up, the idle in park and neutral will be at about 400rpm. When i put the car in gear the idle will drop below 200rpm. Once in a while the car will die out when i gas it real quick in drive or reverse. Has anyone ever had this problem? I searched for this but in the forum but couldn't find anything similar to this. any help would be great.
Old 10-29-07, 05:01 AM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Welcome. There's a forum here that says "engine" right by the button you pushed to post this and that's where this is going.
Moved.
Old 10-29-07, 07:27 AM
mkorsu
Zombie Slayer
mkorsu's Avatar
Turn your throttle positioning sensor about 1/8 inch to the right.
Old 10-30-07, 01:18 PM
Lexus082
Lexus082's Avatar
I also have the same problem. Exact same issue. I have about 200,000 miles also. So far I have cleaned the throttle body, replaced tps sensors, replaced fuel filter, swapped throttle bodies, swapped mass air flow sensors, replaced pcv valve, air filter, reset ecu, checked for vacuum leaks, cleaned IACV etc. I took it to toyota and they couldn't find anything wrong.
I also have a misfire. I'm hoping its related to the distributor caps and rotors. I have already replaced the spark plugs and plug wires. I will be replacing the caps and rotors as soon as I receive them via UPS. I'm hoping its not the iacv. Try adjusting the tps like mkorsu suggested. I will try adjusting mine after I get this misfire corrected.
Redrek43
02-18-13 05:44 AM
Bassrocker
39
10-09-12 04:17 PM
vham62
SC- 1st Gen (1992-2000)
04-08-11 01:19 PM
vham62
03-30-11 05:44 PM
jfmjr
07-30-10 05:08 AM
Quick Reply: 92 sc400 idle problems
