pic request
Old 10-31-07, 04:34 PM
clean
clean's Avatar
Default pic request
ive been look through threads and cant find, please im trying to replace my spark plugs on my sc300 but can somebody give me a pic of what part to take off the intake and manifold so that i can get to the spark plugs thanks
Old 10-31-07, 04:45 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
and yet again....
Old 10-31-07, 06:48 PM
Dx3
Dx3's Avatar
If you can post a picture of your engine bay showing the top of your motor I can circle everything you need to take off.
Jonny
Old 10-31-07, 07:16 PM
habitat
habitat's Avatar
Hey OLT how about something a lil more festive?
Old 10-31-07, 07:20 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
tis the season.
Old 10-31-07, 07:25 PM
clean
clean's Avatar
i dont have my camra rite now so i used another pic, but its the same thing thats under my hood, so could sombody circle the spots thanx
Old 10-31-07, 07:41 PM
TheMole
TheMole's Avatar
I just replaced my wires a few weeks ago. I'll post some pics and links that I used when I get home. Just gotta turn some bolts, take your time, and be patient. It is a good time to replace the spark plug wires as well if they are old to save you the trouble down the road.
Old 10-31-07, 07:53 PM
clean
clean's Avatar
lol yea its time i only had the sc300 for a couple of months and it still has the wire's and spark plugs from 1993 lol, everything is original from 1993 but ive just had the gasket set done
Old 10-31-07, 09:32 PM
TheMole
TheMole's Avatar
Yea man the wires on my car had "1992" before I changed them. Not sure if you have found this link, but it was very helpful when I did it: https://www.clublexus.com/forums/sho...d.php?t=103316
I ended up using the method that removed the throttle body because I could not find a way to reach this one bolt on the upper Y intake manifold.
Here are some directions from the manual. I used the directions on the thread mentioned above. The following directions are from the manual:
Spark Plug specs:
Electrode gap 0.043 in (1.1 mm)
Torque value 13 ft.lb (18 Nm)
1. Remove wire covers.
2. Remove throttle body. Refer to FUEL SUPPLY AND AIR INDUCTION .
Disconnect negative battery terminal.
Drain engine coolant into an approved container.
Disconnect cables from throttle body.
Disconnect PCV hose from valve cover.
Disconnect power steering air hose from timing cover.
Remove throttle body bracket.
Remove the following connectors and hoses:
Throttle position sensor
Sub-throttle postion sensor (if equipped)
Sub-throttle actuator (if equipped)
IAC valve
4 vacuum hoses
Remove throttle body mounting hardware.
Disconnect 2 water bypass hoses.
Remove throttle body and gasket.
Reverse procedure to install, using a new gasket and noting the following torque values:
Throttle body - 15 ft.lb (21 Nm)
Throttle body bracket - 15 ft.lb (21 Nm)
Old 10-31-07, 09:42 PM
clean
clean's Avatar
yesss thanx, i was just in my garage lookin under thw hood lol now i can get started, good lookin out
Old 10-31-07, 09:58 PM
TheMole
TheMole's Avatar
No prob good luck with it. Hit me up on aim if you get stuck.
Old 10-31-07, 10:46 PM
pnyboy27
pnyboy27's Avatar
changing our spark plugs suck! so much to remove..i wish it were a bit easier..
Old 11-01-07, 08:26 AM
Zeal3
Zeal3's Avatar
i agreeee. ive changed our LS400 and toyota celica's spark plugs and it was do-able in about 30 minutes. i think im just going to get my spark plugs done at a shop next time. bcs its time consuminggggggg.
Old 11-01-07, 10:06 AM
Gunnar
Gunnar's Avatar
Drain engine coolant? I don't even disconnect both coolant lines. I disconnect the one underneath the throttle body, and unbolt the bracket holding the throttle cable to the y-plenum, and just move the throttle body off to the passenger side rear of the engine bay with the other coolant line still hooked up.
Old 11-01-07, 11:11 AM
clean
clean's Avatar
sc300max and the rest of you guess thanx for the input and makin it real easy for me, and gunner, yea i just moved it to the side, its was hard tring to get that line off with that oem clamp on there, but thanx and it took me 35 min it will prolly be 20 min next time lol
Quick Reply: pic request
