12 MPG!! I got a plan. Anything else?
Old 11-02-07, 07:20 AM
madmax98
madmax98's Avatar
Default 12 MPG!! I got a plan. Anything else?
I bought the sc300 2 months ago and it has been ranging from 12 to 14 MPG which is insane. Finally, i have sme time to take a look at it. I'm planning on changing the plugs, oil, oil filter, fuel filter, coolant, tire pressure, air filter and transmission fluid, of course i'm going to check compression
do you guys recommend anything else, or have you found something in particular to be the reason of poor millage in sc's? thnx in advance.
Old 11-02-07, 07:21 AM
madmax98
madmax98's Avatar
oh and the car is a 98 SC with 81000 on the clock.
Old 11-02-07, 07:25 AM
laxdude362
laxdude362's Avatar
Damn on a 98 with low miles. I would go ahead and do spark plug wires as well, dist. cap and rotor, seafoam (search for it on here), make sure you fill up with premium gas also.
Old 11-02-07, 09:49 AM
fwynn
fwynn's Avatar
yea seafoam is a must.. all well as all those things u mentioned..
soo
SEAFOAM first..
Change OIL
Change OIL FILTER
Change SPARK PLUGS
Change Wires
Change Air Filter
Change Tranny Oil
*Change Tranny Filter <-optional really...
Change FUEL FILTER when ur almost/to empty..
and the MAIN THING to save gas..
drive it normally ;] ahaha
u dont have to change coolant really... but i guess since ur changing all of em.. MIGHT as well huh?
Old 11-02-07, 10:32 AM
93MSB
93MSB's Avatar
do the 98's have distributors? i know 98 was the year they switched the na supra to the vvti w/ coil packs
bad o2 sensors could give you bad mpg too
Old 11-02-07, 01:42 PM
madmax98
madmax98's Avatar
only God knows that i baby that car driving; i don't let the tach go over 2300 RPM. so i know it's internal. Do i get OEM wires and cap, or is there a brand you recommend?
Old 11-02-07, 01:43 PM
madmax98
madmax98's Avatar
ya, the 98 SC has a distributer. and i don't have any codes for anything including O2 sensors.
Old 11-02-07, 02:18 PM
comoSC
comoSC's Avatar
I've got a 98 SC and I don't have a distributor. I think we have a coil on plug distributorless system.
Old 11-02-07, 05:00 PM
evileagle
evileagle's Avatar
dont forget to change your O2 sensors....
Old 11-02-07, 05:20 PM
Curry
Curry's Avatar
The seafoam and air filter are probably gonna make the biggest difference. I just did mine the other day and the car is running even better and it stopped drinking gas!! I still have to do the plugs, wires, caps and fuel filter but im leaving the fuel filter to a shop since i hear its a pain in the ***.
Old 11-02-07, 06:15 PM
madmax98
madmax98's Avatar
you're probably right because i don't see a distributor.
Old 11-02-07, 06:40 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Old 11-20-07, 03:20 PM
Luke_in_SD
Luke_in_SD's Avatar
any updates on this?
Old 12-17-07, 04:47 PM
Luke_in_SD
Luke_in_SD's Avatar
bump on your results
Old 12-18-07, 10:29 AM
Devir
Devir's Avatar
There is no distributor for VVT-i engines.
Are there performance coil packs for these cars (sc400/300)? I'm also getting crappy gas milage on my sc400. 12-15 city if i am lucky. I have a nice 5 mile commute to work now though. I've seafoamed all 3 spots, (gas, oil, break booster), changed plugs, changed air filter and have done all the other work. The only thing left are the O2 sensors.
Quick Reply: 12 MPG!! I got a plan. Anything else?
