bucking in my car stopped!! yay!!
Old 11-06-07, 05:16 PM
tuterz
tuterz's Avatar
Default bucking in my car stopped!! yay!!
i had a thread here sometime earlier... about my engine bucking... now its stopped... it was my throttle position sensor... i had it re-adjusted... not my car runs perfect...
Old 11-06-07, 09:10 PM
dejacky
dejacky's Avatar
good to know and thanks for sharing this VERY useful info . Is your sc300 stock or does it have some engine/electronic mods?
Old 11-08-07, 04:41 PM
2muchpsi
2muchpsi's Avatar
can you describe the symptoms of your bucking? Mine is bucking after being warm randomly. Sometimes the car runs great, other times it runs like total ****, stalling out and bucking under everything but WOT.
Old 01-06-08, 02:17 PM
SC300_704
SC300_704's Avatar
that's exactly what mines doin right now for the past couple of months and it's getting really annoying...
Old 01-06-08, 03:43 PM
craaaazzy
craaaazzy's Avatar
mines doing the same but i think it's my tune. only happening when i decelerate, foot off the accelerator between 2k and 1k rpms. i wonder if it's got anything to due w/ the tps...
Old 01-06-08, 11:34 PM
tuterz
tuterz's Avatar
my car was bucking letting off the gas.. and pressing the gas... letting off the gas.. it would buck.. stepping on the gas a little it would buck.. but.. wot it doesnt buck.. stepping on it a little will seem like it has no power for about half a second.. then.. all a sudden it jerks and bucks and has power.. its been a while.. i dont really remember exactly what it did.. but.. i hope it helps.. and the tps was easily adjusted.. remover the plastic valve cover.. then loosen the screw on the tps... enough to move it only.. then turn it counter clock wise.. til it can move anymore.. then.. tighten the screw.. hope this helps..
Old 01-07-08, 03:04 PM
craaaazzy
craaaazzy's Avatar
will have to try, thanks.
Old 01-07-08, 05:07 PM
SC300_704
SC300_704's Avatar
SWEET!!! i did exactly what you said and guess what, i works! i remember taking the TPS off once when i did a spark plug change and i didn't know it can be adjusted like that...thanks tuterz..
Old 01-07-08, 05:49 PM
Gunnar
Gunnar's Avatar
Right on man, glad to hear it's running smooth.
Old 01-13-08, 10:24 PM
tuterz
tuterz's Avatar
glad that helped you..
Old 01-14-08, 08:59 AM
craaaazzy
craaaazzy's Avatar
fixed but not due to physical tps. tps setting in aem. car runs soooo much better. thanks for the suggestion anyway.
Old 01-16-08, 07:01 AM
mamurra2
mamurra2's Avatar
+1 fixed my bucking issue, haha vote this for sticky
to add a little more info, turning the TPS CCW reduces the voltage, mine was set at .60v with throttle closed, twisted it back to .40v and problem disappeared.
Old 03-19-10, 03:51 PM
Track5tar
Track5tar's Avatar
anyone have a picture of where TPS is located on car. I need to do the same adjusting to mine and see if issue resolves..
Old 03-19-10, 05:28 PM
good2go
good2go's Avatar
well.....the Throttle Position Sensor should be located on the throttle body
Old 03-19-10, 08:45 PM
MarcusMIA
MarcusMIA's Avatar
I've heard this also resolves the clunk when we shift the car to reverse, right?
Quick Reply: bucking in my car stopped!! yay!!
