2jz-ge AUTO TRANNY (HP RATING)
how much hp are the stock AUTO TRANNY rated to?
also are the GTE auto tranny a direct swap for the GE cars? (reuse the stock GE driveshaft?)
I have heard about people going to about 400 on the stock tranny with out problems but I do not know if they are direct bolt in's from the GTE I know you need a new drive shaft to convert it to a 6-speed so I am geussing so.
Stock transmission wont last long over 300rwhp. To swap in a TT tranny you will need....The tranny, the TT bellhousing, TT torque converter, TT flexplate w/bolts, the rear tranny mount from the SC400, you can use the SC400 driveshaft or go custom. You will need a standalone ECU like the AEM to control the tranny.
gadgetSC
gadgetSC
MrGi11 (09-15-22)
2jz, 2jzge, auto, automatic, code, horse, horsepower, hp, max, power, rating, stock, tranny, transmision, transmission
