Have the option to swap a obd2 2jgte in a 92 sc
Swap a 98 vvt-i 2jz-gte into a obd1 92 sc.
Has anyone done this and should I go for it? The motor is cheap and good from a friend. I was gonna do a 1j but then this offer came along and I can even get it Legalized by the REF (California). Can't do that with a 1j.
So what do you think?
Former Sponsor - Cancelled
You may be okay. The VVTi 2JZ is OBD2, and there's no need for EGR because it uses the VVTi for that function. I've wired up a few of these so if you need help with that end of it, just let me know. drtweak@phoenixtuning.com or http://www.phoenixtuning.com
-Doc
-Doc
Banned
You can swap anything you want as long as all the parts transfer. What the car came with doesnt matter. If you swap in an obd1 engine use an obd1 harness and use an obd1 ecu, it will be obd1. its just illegal to go from obd2 to obd1 since its a downgrade of the fuel emissions crap. Kinda like its illegal to use a carb on a car that came with fuel injectors.
sure, just longmotor swap them and use all your 97 electronics -unless your 97 is dli- is it? i think 98-99 are right?
shortblocks will be plug and play, check faq for model year revisions thread
jose0513
SC- 1st Gen (1992-2000)
17
06-27-10 08:29 PM
