Aristo 2JZGTE into 92' SC300 5sp.
Hey guys,
i'm in the process of doing the Aristo swap into my 92' SC. its already a 5sp so i will be using the stock trans. The only part i am having problems with is of course the wiring. I have both the Aristo engine harness and the stock SC harness. im going to use the JDM Aristo ECU with the swap so i dont have to convert to mass airflow and all those other USDM parts. Can anyone here help me make a plug and play harness for the swap? any help at all would be much appreciated. im located in SoCal by the way. thanks in advance
Yeah i will most likely end up going through him cause already got a quote from him. i was just seeing if anyone local could possibly do it.....thank you for the suggestion though
Former Sponsor - Cancelled
Thank you guys for the plugs! I'm so glad to hear that your plug and play harnesses are working out so well. I'd be happy to help with the wiring, that's what we do here all day long! ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
http://www.phoenixtuning.com/ or 404-474-4573
-Doc
-Doc
slappy96
Performance & Maintenance
07-24-08 03:23 PM
