usdm and jdm turbos
I just bought a set of used twins from a USDM 2JZGTE. I was wondering if there are any physical or visual difference between the US and JDM twins. I just want to make sure im getting a US spec and not JDM.
Umm I've heard that the usdm has a different exhaust flange or something along those lines, and when interchanging one for the other you must use the whole assembly. I did a search recently and somone said thats the reason a usdm downpipe for a supra will not fit the jdm twins.
"did jdm 2jzgte swap last year and ditched the jdm turbos because supra downpipe was alot cheaper and easier to get than jdm downpipe. jdm cast iron outlet after turbos points in a different direction more down."
and heres the source for the quote![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
https://www.clublexus.com/forums/sho...e+fit+usdm+2jz
once again not 100% sure.
757jetip
Performance & Maintenance
13
08-09-07 11:24 AM
