I want a shortshifter for my w58...............
whut year is your car? i think it varies from 92-94 and 95-97
i think one is ball and socket and and other is the ring type with center bolt or summin... anybody knoe which year goes with which? and if the mk3 supra w58 is the same as the early model w58 on the sc?
If I were looking for a short shifter for my W58, I would find a knowledgeable MKIV Supra n/a guy who would know if the Supra W58 had similar model changes to the SC. I say this because the shifter position between the MKIV and the SC is the same. This can not be said for the MK3 and the SC. That knowledgeable MKIV n/a guy should be able to tell you the short shifter options for the trans as well.
I just did this yesturday. So far I love it, it has a lot shorter throw and feels more solid. It is for a 94-98 mkIV NA and it will bolt right in on the 95-97 sc300. I bought it from an ebay seller for 75 shipped. They do not list them so if someone wants one PM me and I will send you there email address. I paypaled them the money and I had it two days later.
before
After
before
After
****, I wish my shifter was taller!!
I ordered a new super long shift **** to replace this TRUST one I have now.
I just want my throw shorter!!!!!
Looks like, I am gonna just haft to modify the stock one. I will post some pics when I am finished with it. And then maybe I can mod everyone elses shifter with a pre 95 for a small fee.
Im busy with school right now but during the winter i will be making a short shifter for my car. My idea is to basically make a plate that will be sanwitched between the top of the transmission and cover assembly that holds the shifter pivot ball in place. im thinking of making the plate about 1/2". to compensate on the shifter side of things i will cut the shifter stock below the pivot ball and add an extra 1/2" to that by welding in a "spacer". this will extend the level below the pivot ball thus changing the lever ratio. it will take less movement to shift it into gear. i have the aluminum at the shop and my thermal arc tig welder so hopefully i wont be too lazy to get it done.
if anyone sees anything wrong with what im describing and how it will work chime in your opinions.
i will try to make a diagram to show what im trying to do. i have done my clutch last winter and studied the transmission closely before i came across this idea.
LCSC do you have the pictures of that shifter out of the car before you installed it?
They do vary depending what year you have. My little brother's 92 has the ball and socket which I dont really like. My 93 has the ring type with the center bolt. Im using a 96 Supra tranny. I also noticed that my stock shifter sits lower than my brother's stock shifter. But I would still like a shorter throw. Anyone have any suggestions?
i guess i have to play around with mine and report back. if it works i can make a few sets and maybe sell them to people and make some much needed holiday cash, but if it doesnt work i will be stuck with a DD car with no shifter. lol.
I don't have any pics, sorry. If I pull it I will take some. On the one I got it just had a 1/4 inch spacer on top and one on the bottom of the ball. The shaft between the ball and the linkage was about 1/2" longer. I think the 1/4" was just to offset the 1/2" a bit. I was going to make one too when I thought they were about $250 but for 75 bucks I had to pass. GL
There's a guy in the FS section who has a '92 SC300 with a TRD short throw shifter that he said he got from MVP. I talked to Kevin @ MVP (who used to own NAPerformance) and he said he believes that the C's shifters were the only ones that were 95-97 specific, and that the TRD ones should work on our 92-94's, but that the next shipment he'd take a picture of one for verification.
Did you find what you was looking for? Check my thread.
https://www.clublexus.com/forums/sho...d.php?t=319250
xspsi6
SC- 1st Gen (1992-2000)
08-10-11 12:54 PM
