Need review on Short Throw Shifters.
Picture #3 is the one I purchased, mainly because it was cheaper but it is the same ast the shifter in picture #2. #1 didn't look as well made. Now some pointers when installing. The white cap at the end of the shifter is not beveled but the one that are on the OE shifter is. I purchased a beleved one from my local Toyota dealer for $6 Bucks
, anyway the reason being that it will allow more movement between shift and won't feel as stiff. Installing took about a hour mainly due to removing the center console and related screws. If you put the two shifters together you will see that the aftermarket one is better made and sturdier than OE one. It also dropped the height about 1.5 to 2" too. I am going to call the shop tomorrow and tell him that it worked and he should contact a moderator here and see about getting onboard as a vendor. He has a alot of parts that would benefit us.
Now for some pictures, sorry I didn't do a step by step but the battery in the camera was low and I had no way of charging it at that moment.
In this picture I cut the crossmember thinking that the shifter was going to hit it, but it never did. So you there is no need to do so. It's just fiberboard material, no structural integrity was compromised.
![](https://www.clublexus.com/gallery/data/500/medium/DSC009831.JPG)
You can see how well made the the mounting bracket is in this picture.
![](https://www.clublexus.com/gallery/data/500/medium/DSC009841.JPG)
Tomorrow, I am going out to purchase a real nice shift ****.
![](https://www.clublexus.com/gallery/data/500/medium/DSC009873.JPG)
I am willing ask any questions. Again, 1 of the best mods I made on the SC so far. I will be giving it a good working out tomorrow.
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
That is a perfect height, I'm glad you were adamant on buying this because your pictures are starting to convince me that $279+ship is worth the added driving pleasure.
Just got back from extended drive and I must say. The shifter makes a difference in the driving enjoyment. Going to contact the company and give them a kudos for a great product. Try and convince them to become a vendor on here, maybe get a group buy going or somethin. Moderator can you send information on the procedure that the vendor needs to join the site.
The first picture is a C's Shfiter but at $390.00, I think the savings of over $100.00 is worth the chance. But I heard nothing but good things about C shifters.
whats tools were needed to install this? It seems like you can take the whole shifter out from inside without going underneath the car. also can you give us the part number for that white bevel piece youra talking about from the dealership???
![](https://www.clublexus.com/gallery/data/500/IMG_1752_half.jpg)
The white bushing will make it easier to shift. The new bushing on the short shift really make it hard to move the shifter until broken in. Make sure you put some grease on the ball of the shifter before popping on the bushing. Or use the one on the OE shifter if it's in good shape. To pop them off I just used a large vise grip. When placing the shifter in the hole of the transmission get a piece of wood and hammer/mallet and give it a good whack to make sure it is seated good. The tricky part is making sure it's seated while you are trying to align the screws around the base and tighten down. Also, replace the OE boot with the frame and 4 screws because if you do like I did, thinking I didnt need it. You are going to have a whole lot of engine and drivetrain whine come the through the center console. So tomorrow I will be putting that back in. I will take some pictures and post tomorrow.
The new shifter is very precise in gate engagement, you really feel gates. And it doesn't travel as far between gate so, it will take some getting use too.
