Mass Air Flow senor question..
Old 11-22-07, 02:32 PM
RonsSc400
RonsSc400's Avatar
Default Mass Air Flow senor question..
I've got a 93 sc400 and it throws a check engine light. sometimes in reverse or drive it will cut off itself. i took the mass air flow sensor out to inspect it, i notice it has a very small crack at the tip of the stalk at the end. will a small crack effect idle hesitating, fluctuation? help a new lexus owner. i prolly should searched too.
Old 11-22-07, 05:52 PM
Dx3
Dx3's Avatar
Did you pull the code to see if it is your MAF?
Jonny
Old 11-22-07, 05:59 PM
RonsSc400
RonsSc400's Avatar
i have no idea how to check the codes.
Old 11-22-07, 06:00 PM
Dx3
Dx3's Avatar
Quoted yourself...
Jonny
Old 11-22-07, 06:01 PM
RonsSc400
RonsSc400's Avatar
a small plug on the driver side under the steering wheel colum correct?
Old 11-22-07, 06:03 PM
Dx3
Dx3's Avatar
Yes, and I believe there is also one under the hood on the drivers side. Marked with a black case that says "Diagnostics."
Jump TE1 and E1 with a paperclip or something and count the blinks.
Jonny
Old 11-23-07, 06:35 AM
RonsSc400
RonsSc400's Avatar
so a small crack on a maf will effect it ?
wieszkto
11-03-21 11:08 AM
leerocks
12-22-11 09:15 PM
StarkoS14
12-22-09 11:37 AM
shuiyuan
02-25-09 12:48 AM
UNOHOO
RX - 1st Gen (1999-2003)
27
01-19-09 03:52 AM
Quick Reply: Mass Air Flow senor question..
