manual ecu
with a manual rear end, you'll have the gear ratios designed for the 5speed version which isn't bad, but I chose to stick with the 4.27 auto diff in my 5spd because I wanted a faster accelerating car, at the cost of top speed.
The ecus should work exactly the sme, except you wouldnt have to wire in a PN safety switch with the manual.
as do i like the quick acceleration, but dose it affect the gas milage at all, or will it be about the same.
the company i am going to buy the kit from offers two kits
the basic kit which is everything u need to do the swap. 1400 shipped
and the advanced kit which has the ecu dif and gauge cluster. for 1950 shipped
more that likely now i will just go with the auto ecu and and auto dif the only thing that i want out of the kit im buying is the gauge culster.
if you really want the stock gearing of a 5sp i have the internals laying around. i blew up my stock 5sp diff so i put in a auto diff.
you dont need the ecu. the gauge cluster is cool but they all eventually go bad so if yours works just stick with that.
good luck with swap
good luck with swap
