'94 SC400 Transmission Problem
Old 11-26-07, 02:50 PM
SLEXC400
SLEXC400's Avatar
Unhappy '94 SC400 Transmission Problem
Hey guys, recently I've been experiencing problems with my SC delaying intitially shifting into drive when the car is cold (well, cold at least for Miami!). I tried changing the tranny fluid (went through 4 cycles over several weeks). I did not do a flush, as I have read that with 207K miles, I could create even more problems. Today when I was leaving work it must have taken at least 5 seconds to go into drive. It always goes right into reverse and always shifts fine, but it just has that hesitation when it's cold. Hitting the gas just makes the engine rev as if it were in neutral. My local Lexus repair shop says that the transmission is simply wearing out and I'm experiencing low line pressure. Has anyone else had this problem? Could it be a valve body problem? A replacement tranny is over $3K, which I don't want to pour into a car this old. I can probably pick up a used tranny, but I don't want to do that if there is an easy fix. Please HELP!!!!!!!!!
Old 11-26-07, 03:42 PM
Parker Gen
Parker Gen's Avatar
Could be the lines... but than it could also be a heap of other problems.. the only way you can tell, is by opening up the tranny. Once you do that you will know. It's probably your clutches etc wearing, not just the lines.
I'd suggest getting a second hand transmission from somewhere, it's cheaper, and hopefully it'll last at least... 50k. That's if you don't want to put 3k into paying for a re-built tranny. And if the second hand tranny brakes.. so what, spend another $300 and put another in haha.
Old 11-26-07, 03:48 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
sigh........ moved.
Old 11-26-07, 06:11 PM
SLEXC400
SLEXC400's Avatar
Oops! Guess this should have been in the Maintenance forum! Sorry about that! Thanks for the reply anyway ...
Old 11-26-07, 08:29 PM
jmwenick
jmwenick's Avatar
Try putting in some Lucas Transmission fix. If that doesn't do anything, shell out some cash and get it looked by a transmission shop, don't go to a regular mechanic. Because they'll look at it, tell you to go to a tranny shop, and then give you a bill for $50. Yeah, I've been there.
Old 11-26-07, 11:55 PM
vntperform
vntperform's Avatar
Sounds like its time for a rebuild or a ne-used unit.
From what your saying the clutches inside the trans are more then likely worn which is causing the low line pressure and delay in engagement.
Old 11-27-07, 04:58 AM
SLEXC400
SLEXC400's Avatar
Yeah --- I have a feeling it might be just wearing out. This transmission has by far lasted longer than any other I've had. It's just so weird that it shifts perfectly. Just that pause going into drive (reverse is fine) when it's cold. I guess I could try an additive, but I think they work by softening/swelling the seals in the transmission, so I've been reluctant to try them. Oh well, I'll keep everyone posted ...
vstolyarov
04-25-07 02:28 AM
REG99GS3
Performance
14
11-14-06 05:11 PM
buuzy
08-02-03 07:00 PM
94GS300
01-16-03 12:30 PM
lionj
SC- 1st Gen (1992-2000)
01-01-02 04:12 PM
Quick Reply: '94 SC400 Transmission Problem
