Rough idle, Coolant leak between valve covers SC300
I have a '92 SC300 that is idling rough. Coolant was low so I looked for a leak. There was a small puddle on the ground and I see coolant in between the valve covers with the cylinder head rear cover off. I can't tell where it is coming from. 201K miles, oil dipstick does not appear milky. I read a head gasket would not leak outside the engine. Is this true? No CEL and temp guage has been no higher than horizontal. Any help appreciated.
Thanks the dealership tech forgot to reconnect the coolant bypass hoses on the rear of the eng. It now has a miss as well. It now has a miss, would the coolant have fouled the plugs? The coolant reservoir was empty.
SHOoff11
19
07-22-15 08:17 AM
Maxx941
03-19-10 04:46 AM
