Power Steering Or ATF Fluid ?
Old 01-30-08, 09:27 AM
LEXUSver
LEXUSver's Avatar
This was the same question I had. Based on the Owner's Manual (92 SC300), you should use ATF Dexron II (Dextron III replaces the older one). I don't like the color of my power steering fluid. It is dark instead of red. I siphoned some of it using a hand pump but I am not satisfied. What I intend to do is completely drain the existing fluid and flush it and then replenish with a fresh ATF. Is there a drain plug or a pet **** that can be opened to make this happen? Any recommendations?
Old 01-30-08, 01:40 PM
FormosaSC
FormosaSC's Avatar
Originally Posted by fwynn
i used the Dexron II stuff.. or like mobil 1 tranny fluid.. or yea..
any ATF fluid really for the PS pump. but iono about like T4..
+1 i use the same thing, one bottle can last for 3 changes
babyduke
ES - 5th Gen (2007-2012)
08-24-18 12:33 AM
acarapella
01-22-18 09:24 AM
hlu1
IS - 1st Gen (2001-2005)
02-22-13 11:53 PM
cheez
SC- 1st Gen (1992-2000)
08-28-11 10:08 AM
Luke_in_SD
05-21-08 07:49 PM
Quick Reply: Power Steering Or ATF Fluid ?
