O/D Flashing
O/D Flashing
Guys,
Been through the old posts and have seen it is transmission related - TC, solenoids etc. It was too dark last night to pull the codes so I am doing some research before I get home tonight.
It is from a 92 SC300 which appear to be infamous for this problem. Seems most people have to replace a solenoid or two. What I couldn't find however, is where exactly is this solenoid located. People said they replaced it, but didn't mention where.
Anyone wonder if a flush might correct the problem?
Hard to search for "O/D" in the CL search.
Jonny
Jonny
has anyone tried doing this? would it be the same as a supra?
http://supraforums.com/forum/showthread.php?t=433076
I had a flashing O/D on my soarer (SC400) and the fault was finally tracked down to the main ECU which had some faulty capacitors. I know it is not a SC300 - but if all else fails maybe swap ECU out with a known good one.
