DIY: How to relocate the wiring harness your tire had for lunch v. LOL
Keeper of the light
You know you guys are not supposed to rub. That kinda signals an issue. If the suspension is properly set up, your bump stops or limiters would protect the fender well from damage. Yeah the wiring getting chewed is an issue, but improper suspension setup is the real issue. It ain't supposed to rub, and there are others plenty lower than most that do not rub due to them setting it up correctly and not just throwing springs or coilovers on there and dropping the car. This fix in this thread is a tedious wiring job that takes hours and causes you to have to cut a factory harness. For about the same amount of time you can come up with a good design for limiting your suspension.
This looks really familiar-i'm having flashbacks....After getting coilovers and dropping the car over my 19z, it was time to feed my wire harness to my brand my tires and boy did they make a real mess of things, i caught the damage right before it did any major damage though. i did not relocate the wiring but, placed it higher into the fender and bent back a thin sheet of steel and reformed it into the fender protecting the wiring and keeping everything safe. i then adjusted the suspension to the proper height (just before rubbing with room for bumps)and have been cool ever since.
nextlevelcoupe - Where did you bend the metal? I tried to create an opening where it was chewed through but that metal was impossible to bend, even with a heat gun blasting away at it.
i thought this one was better! http://www.youtube.com/watch?v=0Rj7R...eature=related
that rubbin looked nasty!
