Rim fitment....I know I read the "Sticky"
I don't see anyone running an 18" 8.5 front 9.5 rear wheel with a 35mm backspacing? Would these stick out horribly?
The wheel fitment sticky says you can go as low as 38 but I see guys with 24" backspacing and just slightly rolled fenders?
Can't seem to find anyone that ran a 35mm backspacing... I'm torn
I found a great deal on knock off ADR rims that look like the Ruff rims I want but they are of course 35mm BS...
What do you all think? Could I get away with it and not get the roller skate look? Just shaved or slightly rolled fenders?
Also if it matters the factory ride height is going to be dropped 1/2 inch. When my supra struts and springs arrive.
thanks!
thanks!
![No No No](https://www.clublexus.com/forums/images/smilies/nono.gif)
you have broken rule number 2 of the SC fourm
2. never lie to the O.G's
but I feel you were trying to avoid breaking rule number 17 --
17. no sunken rims...
you have to read the whole thread. It will answer questions you have and some you haven't thought of....
Im suprised you didnt find anythign in those offsets. Those seem to be the MOST common for cheap rims. 8.5/9.5 +35. They will fit easy, but I would seriously consider some spacers to make them look better.
Add in the cost of the spacers and you could use that extra $200 for something better?
200 bucks for spacers? That seems high to me.... Where are you getting the spacers from? How large of a spacer would be needed would I have to get longer wheel studs or something?
Reading through that rim thread would take days theres like 100 pages... but I did come up with this... And they are claiming 18x8.5 and 18x9.5 with a 35mm offset sets the rims flush with the fenders? Is this correct? Or is there also misinformation in the sacred tire/rim fitment thread?
And this...
Originally Posted by mr2turbo12 View Post
im looking at these ruff 278 http://cgi.ebay.com/ebaymotors/Ruff-...40980566QQrdZ1 the size is 18x8.5 front, 18x9.5 rear +20 offset for the front and rears. From reading thru these forums +35 makes the rims flush with the fender. So +20 should stick out 10mm, correct? I am going for an aggressive look, but would this look to aggressive for a stock body? Also can someone recommend tire sizes. I am willing to roll the rear fenders, but would rather not roll the fronts.
thanks in advance.
thanks in advance.
Here's my contribution....
Kazera KZ-A
F 18x8.5 +38mm 245/40
R 18x9.5 +35mm 285/35
Shaved rear's
Great fitment!
Kazera KZ-A
Shaved rear's
Great fitment!
MarcusMIA
SC- 1st Gen (1992-2000)
10-12-09 09:39 PM
