2jzgte in my SC300.... Ran fine then I had problem help please!!!!
Old 12-07-07, 10:27 PM
isc300t
isc300t's Avatar
Default 2jzgte in my SC300.... Ran fine then I had problem help please!!!!
mechanic installed an Aristro GTE into my SC... i got it started and it started right up ( no water , I crank it right up and stay on for 30sec). after I changed out the fuel pump to walbro 255lph put more water in to the radiator , then the car having hard time to start , ran a compression test ,and the result -
cylinder 1 150psi
2 100psi
3 100psi
4 110psi
5 150psi
6 150psi
then I pulled some oil in to the cylinder 2 and ran the compression test again got back up to 150psi ....
my question is I wonder if I have a blown gasket, or if it's the worn piston ring... damn it I just got the motor in .
i did not change out the aristo water pump to the supra pump..... I don't think it is the problem thou
Old 12-07-07, 10:35 PM
isc300t
isc300t's Avatar
I extend the hose for the map sensor. I doubt that make any different.. what could be a problem? the motor have compression so I believe it should start right up and stay on... blah...I'm so confused.
Old 12-07-07, 10:36 PM
isc300t
isc300t's Avatar
by the way I"m using stock everything...Aristo ECU arsto harness( non-extended)
destinyxo
GS - 1st Gen (1993-1997)
03-01-15 04:25 PM
Murvilboy
20
08-15-12 01:04 AM
lexylexus
SC- 1st Gen (1992-2000)
12
07-13-09 02:32 PM
menty
01-23-09 09:06 PM
Quick Reply: 2jzgte in my SC300.... Ran fine then I had problem help please!!!!
