Help me diagnose my oil leak!
Old 12-19-07, 04:18 PM
100mgbluep
100mgbluep's Avatar
Default Help me diagnose my oil leak!
So over the past few weeks ive noticed on my exhaust side a few oil leaks. The most obvious are the valve cover gaskets which im going to replace in the next few weeks. There is one more right below the distributer and above the water pump that is concerning me. What gasket/seal in in that vacinity? Other than the distributer (which i have already replaced)?
Old 12-19-07, 06:55 PM
Sc dRifta
*****Do not buy from this member until further notice *****
Sc dRifta's Avatar
valve cover gasket
distributor O ring
are u turbo?
maybe turbo oil return those are teh common leaks
Old 12-19-07, 06:59 PM
100mgbluep
100mgbluep's Avatar
Im installing my kit next weekend but as it sits its na. I really want to figure this out before my install so i dont lose all of my oil while my turbo is installed. It leaks so bad that after i fill it up, a couple of weeks later i will only have about a 5th left. That 5th wont leak out for some reason either. Would the valve cover gasket leak all the way down there?!?
Old 12-19-07, 08:40 PM
D1GP
D1GP's Avatar
you should just pick up a gasket kit and change all your gasket if you are going turbo...
Old 12-19-07, 08:42 PM
100mgbluep
100mgbluep's Avatar
Thats what i plan on doing but there are two different kits i can buy and i want to make sure i get what i need to stop the leak.
Old 12-20-07, 12:36 PM
100mgbluep
100mgbluep's Avatar
Some pics:
Old 12-24-07, 09:15 PM
100mgbluep
100mgbluep's Avatar
anyone know?
Old 12-24-07, 10:08 PM
5sp_jzz30
5sp_jzz30's Avatar
my only guess is VC or distributor O-ring. thats the only oil related things in that vicinity.
Old 12-24-07, 10:13 PM
Luke_in_SD
Luke_in_SD's Avatar
best thing to do also would to clean all the off everything. and then when the leak starts you will be able to narrow down where it is since everything is clean.
Old 12-27-07, 09:41 AM
qmanlexus2
qmanlexus2's Avatar
It defenitly the Dist O ring and some is the Valve covers. I just changed mine it was the same thing. The O ring was hard as a rockand just broke in my hands. My valve covers were leaking so bad when bought the car that lexus thought it was the rear main seal. Make sure you clean everything after your done so that you know if it leaking again.
Cuv15
02-17-19 01:10 PM
rerose
01-25-18 11:23 PM
Ohoopee
IS - 1st Gen (2001-2005)
09-10-17 05:40 AM
dubstatus
GS - 1st Gen (1993-1997)
12-07-16 07:27 PM
zero44
12-15-09 03:26 AM
Quick Reply: Help me diagnose my oil leak!
