1jz swap how-to, hopefully a sticky... eventually
Old 06-27-08, 01:10 PM
CCC-TT
CCC-TT's Avatar
you cant use the GE ECU. you can use the auto 1j ECU with your 5spd transmission, thats what i did. and yes, you need to cut and solder the speed sensor plugs and i would also suggest extending the wire a little bit just in case.
Old 06-27-08, 01:15 PM
shern
shern's Avatar
You can not not use the GE ECU with the GTE motor.
You can use the auto GTE ECU with the 5 speed.
Old 06-27-08, 05:13 PM
OneJay
OneJay's Avatar
Which plug is the speed sensor plug? The larger gray one, or the smaller black one?
Old 01-19-09, 01:55 PM
RyanV
RyanV's Avatar
So, has anyone figured out the airbag light yet?
Airbag light on=airbags not being functional
that scares me as I've experienced an airbag up close and personal and they work!
Old 01-19-09, 05:36 PM
celiman05
celiman05's Avatar
my airbag light never came on i dont think. i know i had to mess with the wiring to a couple of the pass side body plugs. basically i compared wiring diagrams and put wires in the correct pins. try looking through diagrams of those body plugs to see if the problem lies there.
Old 01-19-09, 07:52 PM
RyanV
RyanV's Avatar
Dude, I'll never figure that out. Wiring to me and reading schematics is like trying to decipher Hieroglyphs...it ain't happening.
Old 01-20-09, 04:34 PM
celiman05
celiman05's Avatar
hahaha. true for me also. i suck at wiring, but after studying the schematics for a while i figured it out. im sure somebody on here has the answer for you. good luck man.
Old 01-20-09, 10:34 PM
RyanV
RyanV's Avatar
thanks bro, just started pulling the 1jz harness off the engine tonight! Got down to the crank angle, and I gave up for the night.
I'm going to have to pull the harmonic dampner to get to it.
EDIT: Didn't need to pull the crank angle sensor in order to send harness to Phoenix Tuning.
Old 12-10-12, 07:04 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Noticed alot of 1jz swaps here lately. Bumping old but great info....
Old 12-11-12, 02:59 PM
OneJay
OneJay's Avatar
THIS
This thread saved me so many headaches when I was doing my swap.
Old 12-11-12, 04:06 PM
StiCk3
StiCk3's Avatar
same here, remember going to this and many other threads for info...plus inspired me to make my own
Old 12-11-12, 04:10 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Well good. Love the bump option. . Also helped me too..
Old 12-12-12, 09:49 AM
spoolxexo
spoolxexo's Avatar
It's all well and good, but there are many more Chaser 1jz's left then the snap-in soarer 1jz that only needs 18" of extending wires.
I think that is more relevant now then when this thread was referencing the Soarer 1jz's.
simplified
01-29-12 12:44 AM
Answer300
22
07-24-07 06:32 AM
SC300_704
12
11-05-06 12:13 PM
2.5tsoarer
80
04-23-05 10:02 AM
ViPeRHunTeR
11-15-02 05:09 AM
Quick Reply: 1jz swap how-to, hopefully a sticky... eventually
