Hyperblink fix for 92-94 SC w/ 97 Taillights
Old 06-14-17, 04:17 PM
  #76
Luxor
Luxor's Avatar
You know you can buy a $10.00 LED flasher that swaps out with the OEM one and gets rid of the hyper blink.
Attached Thumbnails Hyperblink fix for 92-94 SC w/ 97 Taillights-led-flasher.png
Old 06-15-17, 05:55 AM
  #77
super400
super400's Avatar
not on the 92-94s. It's a totally different flasher.
Luxor (06-15-17)
Old 06-15-17, 06:06 AM
  #78
mrmj2u
mrmj2u's Avatar
Tried, but it doesn't fit. These flasher relays have 5 pins.
I plugged my $10 3 pin relay in and tried to use the flashers and nothing lol.
Old 07-17-17, 08:13 PM
  #79
Deathbarel
Deathbarel's Avatar
what does it mean when they say wire in the 4 mf capacitor with the stock 3 one? as in 2 cap's in one hole
Old 07-18-17, 06:20 AM
  #80
aletz12485
aletz12485's Avatar
I used a 3-prong led flasher in the 5-pin slot and it worked.....just for the drivers side blinker. Worked great at the correct speed. Just didnt work on the passenger side. Probably because its only a 3 -pin. (ordered a 3-pin thinking it was a 5 on Amazon for some dumb reason)
I shaved the rod down as shown in the first post and it slowed the blink rate.
Old 07-18-17, 11:12 AM
  #81
Deathbarel
Deathbarel's Avatar
where is that slot for a standard flasher relay i thought it was controlled by the box where you swap capaciters
Old 07-18-17, 11:16 AM
  #82
aletz12485
aletz12485's Avatar
i installed it in the same slot as the factory one (drivers side kick panel)
Old 07-18-17, 11:50 AM
  #83
Deathbarel
Deathbarel's Avatar
i see it now. its so much bigger than modern ones thats what threw me. thank you very much, i like your solution.
Old 07-18-17, 12:11 PM
  #84
aletz12485
aletz12485's Avatar
my solution doesnt work. It was a 3-prong and the factory lexus is a 5-prong. There is no 5-prong LED relay available for our cars from 92-94. Only solution is to do whats done in the first post or to do some solder work to mimic the stock flasher speed.
Old 07-18-17, 01:11 PM
  #85
Deathbarel
Deathbarel's Avatar
amazon sells led flasher relays in 5 pin
Old 07-18-17, 04:09 PM
  #86
mrmj2u
mrmj2u's Avatar
have you tried one? Do the pins line up?
Old 07-18-17, 04:33 PM
  #87
Deathbarel
Deathbarel's Avatar
have not tried it, the pins line up
Old 07-18-17, 07:02 PM
  #88
mrmj2u
mrmj2u's Avatar
very cool! I looked but couldn't find one. Modified my original and it works perfectly
Old 07-19-17, 06:34 AM
  #89
aletz12485
aletz12485's Avatar
post up the link to the one on Amazon
Old 07-19-17, 08:01 AM
  #90
Deathbarel
Deathbarel's Avatar
Amazon Amazon
Quick Reply: Hyperblink fix for 92-94 SC w/ 97 Taillights
