Blitz Nur-Spec Muffler Pictures
I would like to get that resonator section and will try to call them tomorrow to see if I can just order that section and find out what it is made of. I hope it is stainless.
If you get an answer from them, can you post it here?
I would like to get the front section (no muffler) only as well.
thanks,
Peter
interested in the front section also
I would like the front y-pipe w/ silencers only as well. I wonder what size diameter the piping is? The pic indicated 65mm, which is bigger than the Greddy, but not sure if that is the spec for the section w/ the mufflers only.
pls post when you find out - maybe we can get a volume discount!
$625 shipped
I found them for $625 shipped at groupbuycenter.com. They are 70mm in case you are wondering and the silencers are an extra $100. I am thinking about getting them as well. I took off the center resenator last week and need something to help quiet things down.
Thanks,
Peter
I found this setup at www.cyberauto.com (<~~ prevously posted) and they list them as a SC300 exaust. You have them on your 400. And the piping seems a bit large (70mm i believe) for a stock SC300. is there any difference between your exaust and the one bee'n sold at cyberauto?
Performance
Have you noticed any performance gains from the exhaust setup? I like the way it looks but I couldn't pay that much unless it really helped me. How did it do for you ?
After I checked out my stock rear mufflers,and discovered that they're in fact large resonators(straight through),not reverse-flow,nor the reflective type,I decided they can stick around,after all.It pays to check these things,and only wish I'd done so sooner.
