Fuel Pump ECU diagnosis
Old 12-26-07, 07:00 AM
Bob'sSC400
Bob'sSC400's Avatar
Default Fuel Pump ECU diagnosis
Thanks to those that helped me diagnosis my 92 SC400. The fuel pump ECU lasted about 100K miles.
Here were the symptoms:
The car would start when cold.
It would not restart after it had been driven. It would need to sit for a couple hours.
In it's feabile attempts to start it was starving for gas and the engine would shutter and shake then die out.
It would not die while driving but simply wouldn't restart after it had been driven for a while.
Here was the solution:
Found a used FP ECU from a 93 SC400 on ebay for $68 and had it shipped next day. All in all it cost me less than a $100.
Took out the back seat and the back driver side panel.
The Fuel Pump ECU is located right behind that panel.
It took me no more than 30 minutes to take it apart, replace the ECU and put it back together.
It is running perfect now.
Thanks for the input!
Old 12-26-07, 09:46 AM
JesLet
JesLet's Avatar
There was a DIY for this, where they connect 2 wires from the fuel pump ECU.
Old 12-26-07, 11:12 AM
Bob'sSC400
Bob'sSC400's Avatar
I saw that. It was to bypass the fuel pump ecu and have the fp run at 100%
Old 12-26-07, 11:36 AM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
This is why we have an engine forum.
Moved
Old 12-26-07, 02:41 PM
Bob'sSC400
Bob'sSC400's Avatar
Moved
And that is why there are mods to let us know these things! Thanks
V8drummer
10-16-13 07:33 AM
brad11140
SC- 1st Gen (1992-2000)
02-04-11 05:45 PM
acenase
04-16-09 04:15 AM
clean
05-20-07 10:03 PM
808SC300
Maintenance
10-07-04 09:31 PM
Quick Reply: Fuel Pump ECU diagnosis
