High RPM's @ cold Idle
Old 12-26-07, 11:31 AM
qmanlexus2
qmanlexus2's Avatar
Default High RPM's @ cold Idle
Hey Guys
I need help. My 93 Sc300 Idles about 1900 to 1800 RPm's during cold starts at any outside temperture. I have some valve noice at intical start up but i goes away imediately. At this high idle I think the oil doesnt have engought time get to the heads. i just started doing his about 2 months ago. I just replaced the o2 sensors with denso universals 234-1057. The car was a bit more responcive but I still have this problem. I have searched all the posts and nothing on this topic. What should the cold idle be on a 93 SC300? About 5 months ago I replaced the valve seals with Timing belt cam seals water pump the works with all Toyota factory parts. I at am a loss. dont know what else to check. Sometimes after warm up the idle stays at 800 to 900 and then after 30 secs drops down. Help!!!!!!!!!!!!!
Old 12-26-07, 11:36 AM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
This is why we have an engine forum.
Moved.
Old 12-26-07, 11:42 AM
qmanlexus2
qmanlexus2's Avatar
Thanks for redirecting the tread. I hope someone can help
Old 12-26-07, 11:57 AM
sc250tt
sc250tt's Avatar
Mostly all fuel injected cars idle high on startup because the computer tells it to do so. If the car did not have this feature i doubt it will be posible to get it to idle on colds day startups. What you are probably hearing is your rod bearing. The sound is only there for a few seconds because that how much time it takes for the oil to pump to the bearing. What type of oil do you use? how much miles is on the engine?
Old 12-26-07, 12:07 PM
qmanlexus2
qmanlexus2's Avatar
Thanks for the quick reply. The car has 105K on it.
Old 12-26-07, 12:08 PM
qmanlexus2
qmanlexus2's Avatar
I am using Valveline & Castrol. Just regular oil
Old 12-26-07, 12:18 PM
sc250tt
sc250tt's Avatar
what body oil?
Old 12-26-07, 12:57 PM
qmanlexus2
qmanlexus2's Avatar
can you adjust the cold idle on the SC300
Old 12-26-07, 01:02 PM
sc250tt
sc250tt's Avatar
i dont think that is possible, not with a toyota ecu. use the recommended oil which i believe is 10-30 .These engine dont like the cold to much so running the proper oil is required when its cold.
xCWolf
09-02-18 08:26 AM
dylanoj
35
01-28-15 10:26 AM
Danimal
Maintenance
03-04-10 07:14 AM
rbini100
05-25-04 09:06 PM
Quick Reply: High RPM's @ cold Idle
