altanator help asap
Old 01-04-08, 12:59 PM
thebadz32
thebadz32's Avatar
Angry altanator help asap
Im trying to pull my altanator off of a 93 sc300 got the top bolt off but the bottom one looks like a very small torx head bolt, is that what it is if so any one know what size it is so i can go buy or borrow one. need to know asap so i can finish pulling this off and go get a new one.
Old 01-04-08, 11:38 PM
TheMole
TheMole's Avatar
The top and bottom bolt should be the same. I didn't notice a difference as I used the same ratchet for the top and bottom. There is a bracket under there so make sure that isn't what you are removing.
Old 01-06-08, 01:56 PM
Supra Dr
Moving SC Threads
Supra Dr's Avatar
Moved to 'Engine section'
The bottom 'bolt' is actually a stud w/ a torx on the end.
which is what you see. A 14mm nut screws on the stud
to hold the alternator.
JosephH
IS F (2008-2014)
01-15-24 01:05 PM
mr2j
13
12-10-16 01:45 PM
shaft1
11-30-14 04:58 PM
bLingIn3o0
02-17-04 01:16 PM
Quick Reply: altanator help asap
