doing a clutch
doing a clutch
ok so im gonna change the clutch in my sc3 and i was wondering the torque specks for the flywheel and pressure plate. and any other needed specks yall think necessary.
also i want to replace as many seals, gaskets as posible when i am doing this which do u recomend.
*****Do not buy from this member until further notice *****
clutch torque specs http://www.cygnusx1.net/Supra/Librar...aspx?S=CL&P=15
flywheel specs http://www.cygnusx1.net/Supra/Librar...aspx?S=EM&P=94
seals
1. rear main seal
2. transmission input shaft seal
3. transmission output shaft seal
4. if it leaks disassemble transmission case and new RTV silicone
5. better get a new flywheel or resurface your or dont bother.....
6. oil pan gasket if it leaks(highly doubt it)
7. transmission mount if yours looks busted
good luck man
p.s use redline synthetic (shamless plug )
seals
1. rear main seal
good luck man
