plz help!!!! how to remove the intake from a 95 sc400???
Old 01-07-08, 07:28 PM
mccube
mccube's Avatar
Default plz help!!!! how to remove the intake from a 95 sc400???
thanks in advance
Old 01-07-08, 07:48 PM
Lexiss_sc430
Lexiss_sc430's Avatar
umm did you search?
There should be 3 bolts holding the actual intake box in place, then you will need to remove the headlight to access the snorkel under the light.
now that you have everything loose, you will see an accordion type rubber boot. Loosen the screw and then you should be able to remove the intake box and snorkel in one shot.
oh and you should only need a 10 mm socket with an extension and a philips screw driver for the removal.
Old 01-07-08, 08:48 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Start by using the engine forum, finish with the search button
salimshah
13
01-28-15 11:40 AM
efrayz
SC- 1st Gen (1992-2000)
06-27-11 01:59 PM
jaxxx
12-23-10 05:46 PM
93sc3005sp
08-30-08 09:59 PM
Quick Reply: plz help!!!! how to remove the intake from a 95 sc400???
