Write up on SC300 Clutch 56K=No No!
Old 03-19-11, 12:28 AM
  #31
broda805
broda805's Avatar
Originally Posted by Jrm87
Im about to start changing my clutch and this is a big help. Just for anyone who needs to know(it took me forever to find and the dealer was no help)
Torque specs
Flywheel to crank 36 ft/lbs
Pressure Plate to flywheel 14 ft/lbs
I'll take some pics while I'm working on it and try and post some up for people. I would think there would be more info on this but it was very hard to find.
Jesse
flywheel bolts are 36ft lbs plus 90 degrees and always use new bolts... alot of tq specs on on the sticker under the hood
Old 04-05-11, 10:19 PM
  #32
skipjagger
skipjagger's Avatar
Originally Posted by lexforlife
great writeup
you mentioned disconnecting speed sensor and reverse lights could you show me a pic with the plug from the harness that plugs into the tranny plug to activate reverse lights
i did auto to 5sp swap and dont know which plug to tap into
this is the plug from the auto trans w/ the reverse light switch
http://a1.sphotos.ak.fbcdn.net/photo...14_1850306.jpg
and these are the 2 wires you attach to the reverse switch on the manual trans it doesent matter which way they are connected its just an on off switch
Old 04-05-11, 10:36 PM
  #33
skipjagger
skipjagger's Avatar
just some pics of w58 stuff vs r154 i also did an auto to w58 swap have tones of pics can someone tell me how to start a new thread or start one for me so i can do a complete auto to w58 swap w/ pics?? i am new to forums pm me cause i dont konw if i will find this thread again lol
r154 in vice marren crawler parts and rebuild kit from driftmotion
maren crawler shift fork
http://a3.sphotos.ak.fbcdn.net/hphot..._2720905_n.jpg
tried to salvage shifter housing from w58 to put on r154 but doesent fit not even close!! ha! pic of w58 /w tailhousing off
http://a7.sphotos.ak.fbcdn.net/hphot..._3573942_n.jpg
http://a1.sphotos.ak.fbcdn.net/hphot..._1883405_n.jpg
pic of w58 easy way to tell w58 appart from r154 the slave cylinder facestwards thr rear of the car on w58 and bolts to trans case with 2 bolts pointing twards driver side r154 slave cly bolts into belhousing facingthe front of the car with the bolts facing the front of the engine
http://a8.sphotos.ak.fbcdn.net/photo...85_4007302.jpg
pic showing 92-94 (I believe thoes are the dates foe this style shifter ??? correct me if im wrong!) shifter housing placed on r154 to sho fittment issues
http://a1.sphotos.ak.fbcdn.net/hphot..._4934075_n.jpg
got a ton more pics someone please pm me and show me how to start a thread or direct me to the correct one!!!
Old 04-05-11, 10:40 PM
  #34
skipjagger
skipjagger's Avatar
oh and w58 92 swan neck (red paint) and r154 swan neck shifter differences got more pics of these 2
Old 04-06-11, 12:22 AM
  #35
abounly
abounly's Avatar
Skipjagger click here
https://www.clublexus.com/forums/new...=newthread&f=6
I am interested i'm gonna tackle this in two weeks!! auto to manual i mean
Old 04-20-11, 12:10 PM
  #36
skipjagger
skipjagger's Avatar
Originally Posted by good2go
This is definitely not the way to do it according to the FSM.
The flex coupling should be left attached to the propeller shaft (so only 3 bolts need removal) and matchmarks should be made for proper alignment when re-attaching back to the diff flange. Also, if you break apart the shaft at the center support bearing, you need to matchmark that too. If you fail to do so, you can't complain about weird vibration issues that arise afterward.
.02
i dont see y you say this?? driveshafts are ballanced withought the rubber thing attached all the holes are semetrical and there is a pin that lines up the rubber thing (flex coupler) and ds on the front of the dif flange. i took mine off the same way and had no issues with vibration, can you elaborate?? if im missing something i would like to know about it
i get that if you take the 2 piece drive shaft appart between the universal joints and put it back together 90 or 270 deg off from its origional location the universal joints will not be lined up properly and THEN you could get a vibration. look up "timing" a drive shaft on google, also put up a little write up on how to do it if anyone is having trouble and reads this, its in the thread i have labled "auto to w58 swap sc300" search "timed driveshaft" it should come up in the advanced search searching whole thread not just titles or whatever
Old 04-21-11, 02:54 PM
  #37
good2go
good2go's Avatar
Originally Posted by skipjagger
i dont see y you say this?? ...
See:
SC300/400 Factory Service Manual
Propeller Shaft Section
Page #PS-25
Old 08-02-11, 01:10 PM
  #38
High PSI
High PSI's Avatar
Question - necessary to drain the tranny fluid before dropping it out of the car, or can you avoid it if you pitch the tranny away from the driveshaft enough? Didn't see any mention of it in the write up. I just changed my fluid recently and would rather not drain and refill it if I didn't have to.
Old 08-02-11, 04:06 PM
  #39
abounly
abounly's Avatar
I think you can do that, but it'll be better if you drain. Cause when i was installing my 5psd, i thought i drained all the fluid and i slightly tipped the transmission and it started to leak fluid where the driveshaft and transmission met.
Old 08-02-11, 10:01 PM
  #40
skipjagger
skipjagger's Avatar
same thing happened to me. i would just clean the whole aria where the oil comes out and drain it into a clean container and reuse it its stupid expensive :/
diss7
Performance
07-29-14 08:35 AM
SOLID300
15
07-11-11 03:56 AM
Slinger
SC- 1st Gen (1992-2000)
16
02-06-07 06:03 PM
gttosc
11-01-05 06:25 PM
David Davis
05-13-01 03:49 PM
Quick Reply: Write up on SC300 Clutch 56K=No No!
