T-61 installed, Troubleshooting...
yeah thats my next main thing. I am working on it. Thanks
Sorry bean. No one answered me for a few days so i didnt check here. Well it runs ok. It dies when its at idle. Goes down and up then down and up then dies. Starts right away not a problem though. Also when i am driving the car it seems like the ECU is freakin out or something when the Turbo kicks in. Might be too lean or something. I am not really sure. I have also changed the distributer cap for the 4runner cap so it fits the turbo. I will check again and make sure they are all right. I checked the timing and it was at 10 degrees and just goes up and down a lil bit. So whatcha thing Bean?? I am not so sure anymore..
I doubt the distributor is the problem either. If it was your car wouldnt run at all. What kind of BOV are you running? Does it need to be plumbed into the intake? Are you 100% positive that there are no vacuum leaks? The engine can die when running TOO rich. IF you're not running an O2 sensor, then you're already running richer than stock; and if there's a mild leak (like a BOV not tightened enough -- if it has an option to tighten it; or a loose coupler), then it could run so rich that it would die.
Running super lean at idle makes it miss sometimes. Its not a hard miss but like a burbley idle noise. Does that make any sense.
Also, did you calibrate your TPS with the Emanage?
I doubt its an O2 problem. The stock ECU goes into a limp mode if the O2 sensor isn't detected and throws a CEL. In the limp mode, the timing map is dialed back and the fuel map is richened. The car can still read an airflow signal, but it cant go into closed loop anymore because it doesnt have a feedback signal from an O2 sensor. This shouldnt affect you and I know of several guys in the early days that did this on purpose because the limp-map was actually BETTER for a turbokit.
kinch09
Performance & Maintenance
04-19-13 10:51 PM
deputy865
10-13-12 12:13 PM
