1JZ in SC400?????
Old 01-21-08, 07:55 PM
LexusFTW
LexusFTW's Avatar
Originally Posted by StiCk3
Dont really have a specific answer for u however, one of the guys on this forum adapted a v160(6speed) to the 1uz and had to use an adapter kit to mate the tranny to the block thus it dont fit (oj gloves) otherwise I doubt he would need the kit. auto trannys are cheap if you intend to go that route with any engine just try ebay or someone on here, everyone likes to switch over to manual not mention the amount of auto trannys to manual tranny ratio, when theres a lot of supply the price will be cheaper.. I swaped my 300 not to long ago and If I were in your spot your going to be stuck doing more wiring for the 400 might as well go 2jzgte just make sure you get a supra one and not the aristo (will be easier).
brain fart, should've known that....
I guess there is a difference between the one out of a 2JZ and the 1UZ. guess the bolt patterns are different, so the A340E out of a 2JZ will fit. srry for the confusion pmpdaddyt!
SC300 and SC400 trannies have different valve bodies. SC400's valve body is electronically controlled. The SC400 auto tranny is the exact same internally as the Supra TT tranny except that the bell housing is different and 1st gear is longer. The SC300 and SC400 trannies also have different bell housings and output shafts.
For the record SC300, 400, and Supra TT trannies say 30-40LE on their tag.
If you're doing a 1JZ swap into an sc400 just get a soarer motorset which should come with a soarer tranny which is for simplistic puposes a SC400 or Supra TT tranny with a manual valve body and similar output shaft as the SC300's.
Old 01-27-08, 01:48 AM
pmpdaddyt
pmpdaddyt's Avatar
hey thanx for the writeup and the correction lexusftw.
sc101
01-23-12 07:48 PM
SC400DRFT
01-31-08 10:35 AM
havok123
09-17-07 09:46 PM
cambo
07-19-06 11:09 AM
Quick Reply: 1JZ in SC400?????
