Any ideas are greatly appreciated...
Old 01-19-08 | 10:41 AM
bucsfan200's Avatar
bucsfan200
Default Any ideas are greatly appreciated...
96 sc300 will run just fine for about 20-30 mins and quit. Restarts right away and will go for a bit and quit again....replaced the relay-efi, fuel filter....any ideas are greatly appreciated here...what could be the issue?
Thanks in advance.
Old 01-19-08 | 11:19 AM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Moved to forum marked "engine".
Old 01-19-08 | 11:24 AM
5sp_jzz30's Avatar
5sp_jzz30
need more details. does it sputter when it runs? how does it just die? is it an instant death lol? or its a gradual power loss and then shut down?
Old 01-19-08 | 11:29 AM
bucsfan200's Avatar
bucsfan200
runs solid, doesn't sputter, gradual power loss and shut down within seconds....30 seconds later re-starts and runs for a bit...thanks!
Old 01-19-08 | 11:40 AM
FormosaSC's Avatar
FormosaSC
well dont think its the battery or starter or alternator problem... sounds like fuel problem?
Old 01-19-08 | 06:24 PM
Kruso's Avatar
Kruso
Does the car die while driving or when its just parked? If its when you're driving it, it could be anything from fuel filter, air filter, and most likely the catalytic converter.
Kruso
Old 01-19-08 | 06:35 PM
97-SC300's Avatar
97-SC300
its probobly a fuel pump ECu, very common........
Old 01-19-08 | 08:55 PM
DasBach's Avatar
DasBach
I agree on the fuel pump ECU being the culprit. Perhaps, there is a bad ground for the ECU or something similar. We had a similar problem with our generators out here; they would die after a half our and have dry fuel lines. The pumps would spaz out from bad grounds and eventually just die. My .02s
tenac2215
03-23-17 11:20 AM
Lexus082
07-10-14 09:31 PM
986ci's
08-05-09 12:57 PM
GRAND_LS 4
SC400 / 300 Classifieds
03-22-07 07:40 PM
kathleenkmh
05-23-02 05:31 AM
Quick Reply: Any ideas are greatly appreciated...
