1jzgte belt
Does anyone know where i culd find an accesory belt for my 1j. Mine is trashed and i would like to replace it before it blows. Ive called all of the obvious places like toyo dealerships, napa , etc. If anyone could help me out it would be great. thnx
the tensioner on the 1jz is a big spring. you turn the tensioner clockwise and take off the belt. you put the belt on you would turn it clockwise, put the belt on, and release. it will tension on its own. just use the 2jz belt. its the same belt. all the accessories are located in the same place and the belt is routed the same way. measuring the length and going to an auto parts store is a good way too. all belts have standard rib spacing. all you tell them is the length of the belt and number of ribs it needs to have. they have a catalog listing what the part numbers are and if they stock it. if you go to NAPA they will hae anything you can imagine belt size wise. i had to do that for my sr20 when i eliminated PS and AC. worked awesome. NAPA will be cheaper then toyota anyways and their stuff is good.
mooseboy84
10-31-15 11:35 PM
rx7guy
04-29-09 12:27 PM
