Power Steering
Old 01-29-08, 07:46 PM
LEXUSver
LEXUSver's Avatar
Question Power Steering
1992 SC300. I found the following but it did not specify which particular seal(s) requires replacement. Can anyone shed light on this please.
Leaking power steering pump: Some of the older coupes have a faulty seal in the power steering pump, which can leak power steering fluid onto the alternator and destroy both parts if the problem is neglected. If you have an older high mileage coupe, be sure to monitor your pump for signs of seep or leakage. Replace the seal for ~$1 or rebuild the PSP for ~$125.
http://intellexual.net/faq.html#03
I can't still locate where the leak is coming from. I suspect that the leak might be coming from the reservoir cap (yellow line) itself because the surrounding and adjacent components are wet/soaked with ATF. I don't think the leak is coming from the vacuum hoses (pink) but I replaced both just in case since they are old anyway. Anyone has experience on this? My thanks in advance.
Old 01-30-08, 04:01 PM
snidehocke
snidehocke's Avatar
Mines leakin LIKE CRAZY too. I need to buy that seal as well.
Old 02-26-08, 10:37 AM
osugrad05
osugrad05's Avatar
Default power steering leaks and car wont stay started
I have 92 sc300 and now it has stop running i guess the pwer steering leaked into alternator so if anyone nows the difficulty on fixing this please let me know
Old 03-10-08, 07:47 AM
Neucorp
Neucorp's Avatar
That's not the P/S pump. That's the reservoir.
Old 03-10-08, 03:46 PM
trangk
trangk's Avatar
It's probably the seal in the front of the power steering pump where the pulley attaches. There's not that many lines going to the pump itself, so if those aren't leaking, look at where the pulley attaches. It's similar to the front main seal on the engine block.
Old 10-11-08, 01:59 AM
xknowonex
xknowonex's Avatar
I dont want to revive an an thread but I am going to do so because mine is making a squeeking noise I think.
For the SC300s, correct me if I am wrong, the power steering pump is on the other side of the engine, not under the ps pump. Thats the SC400
Old 10-12-08, 02:21 AM
SoarerAZ
SoarerAZ's Avatar
any thoughts anyone?
Old 10-12-08, 05:59 AM
2000atlant
2000atlant's Avatar
Why would there be a power steering pump under a ps (power steering) pump? The power steering pump is on the driver's side under the reservoir. if you look at the picture above you can see a power steering line running to the pump directly under the reservoir.
Doc Yota
12
04-17-20 01:31 PM
opisdfagjo
07-20-18 06:50 AM
scrapinls
02-06-18 08:07 PM
daddyswang
GS - 1st Gen (1993-1997)
10-15-11 08:28 AM
Quick Reply: Power Steering
