Losing Coolant from back of motor.
Alright, so lately I have noticed the heating in my car has gotten cooler. I can turn my heat on full blast with the label on the dial reading "HOT" and it would still blow semi-cold air out. Well the other morning I was leaving from work and I had let my car warm up but when I got in my car, it was blowing ice cold air. I checked the heat settings and it was set to "HOT" as usual but no warm air came out.
Well after driving I noticed steam coming from bottom of the drivers side. Well sure enough my car started to overheat and so I pulled over and noticed I had no coolant in my car at all. It had all leaked out. So now I am really curious as to what happened so I put more coolant in it and I see it's leaking from the back of the motor.
What is back there that can leak coolant besides the Heating Coil? Has anyone else had this issue? My car is a SC300 5spd.
Thanks in advance for any help or advice.
thomashmc1
12-18-17 07:29 PM
