21mpg city... SAFCII and 3.76's....
If you have 3.76 gears, did you recalibrate the speedo/ VSS? Just wondering how you measure fuel MPG in this particular case. I've seen 24-25mpg on the freeway with the stock rear end, and have granny shifted my way to a 20mpg in the city. Only limiting factor for me is that I get a low rpm buck around 1400rpm, and can't get into 5th gear until around 40mph. For some reason it just doesn't run well under 2000rpm.
You'll get better gas mileage with your o2's cycling between 15 and 15.5, and adjusting timing to match the proper amount of fuel. Obviously, with the safc, you can't do that, but it would be optimal.
Ian
Ian
Hey all just added the safc2 to my car just have a bfi and exhaust. Planning on supercharging, headers, and torque converter. DX3 and Ihiryu helped a lot when I put mine on. I have an 1992 SC400.
Here are some links that really helped me thanks to Lextreme:
http://www.lextreme.com/piggyback.html
http://www.lextreme.com/pics/apexi.2.gif
http://lextreme.com/forums/showthrea...+wire+diagrams
https://www.clublexus.com/forums/sho...=install+safc2
i ended up soldering and re-working my wires a bunch but now got it going.
-Ben
-Ben
