Sc300 1jz soarer swap
![Thumbs down](https://www.clublexus.com/forums/images/icons/icon13.gif)
Hey everybody i recently bought a 1992 SC300.. i am doing the soarer swap....1jz 5 spd....Now i have a question does anybody know how to tell if the 1jz i am buying came out of a soarer. I ask because i have been told that depending on that i might have to do some modifications to the engine.
There are several ways to tell if they came from a Soarer. Seeing that you only have 2 post with 2 threads you started. I am thinking you might get flamed a little.
You should do your homework first and think about what you are getting yourself into because this ain't no Honda or Nissan.
Don't be afraid to hit that search button.
I agree with the post above. Have you ever considered going NA-T, cause you can get great power from the 2jz that comes in our car. It may not be more or less cost efficient, but from what i've read, it's a lot less headache.
Hope that helps.
due your research on here and you'll find everything you need to know however the info is scattered on different threads.. its a pretty straight forward swap some of the task are hard to due (labor) but it is not hard in the technicality aspect.. Ill suggest replacing water pump timing belt and forward and rear seals as well as pilot bearing and engine mounts. please consider the advice or you'll be taking stuff apart the following week after completing the swap (trust me it happened to me). also inspect your clutch and crank pulley..
llllllllll
SC- 1st Gen (1992-2000)
31
12-30-06 08:56 AM
