MAP sensor=No MAF???
Old 02-18-08, 06:32 PM
Somy6
Somy6's Avatar
Default MAP sensor=No MAF???
I have a 95 SC300 and running the XS kit. I am running the E-manage blue and i also have the Timing harness as well as the Map sensor. So my question is, can I take out the MAF and tune the car with just the Map sesnor??
Old 02-18-08, 07:35 PM
ihiryu
ihiryu's Avatar
usually yes, but i'm not sure with the E-manage. I know with the turboxs utec you can't you have to have both maf and map
Old 02-19-08, 09:12 AM
qksl2
qksl2's Avatar
You can only do that if you eliminate the MAF and have the MAP sensor voltage converted to a frequency that the ECU recognizes as a MAF signal. From there, you tune the voltage to match the fueling that you want.
I've done this with both the MAP ECu (thats what its meant for) and the AEM FIC, but not with an emanage as I find they are not as tunable and less powerful.
Ian
scsexy
12-23-15 08:51 AM
madmax98
07-25-09 02:23 AM
page2two
03-29-08 03:32 PM
Quick Reply: MAP sensor=No MAF???
