Installing traction control in non-TC SC400 ?
I did a search, but didn't find an exact answer to this question.
How hard would it be to enable / install (factory) traction control in an SC400 that didn't come with it preinstalled? I wondering if it is just a matter of picking up the additional ECU, and the shift plate with the TC switches. Does anyone have any insight or personal experience on this?
gadgetSC
The reason I was interested in it was because it is wet / slippery here in Canada for six or eight months of the year, and if it was as simple as throwing in a (now cheap) ECU, then it would have been a nice evening project. I wasn't aware there was an aftermarket one for our cars -- I will look into that. Thanks for the heads up.
It ain't worth it. I have TC on my car and when the roads are slick here from frost or frozen snow meltoff, I can't get anywhere. Shut the Trac off and I'm good to go with no more problems. Not really sure why it's such a great thing.....
Hacked CL to become a Mod
traction kinda sucked if you have aftermarket wheels, the diameter and stagger threw off TC calculations...i spun out with them on...traction control took control way too late...luckily i didn't hit anything
Keeper of the light
Not everybody wants to star in fast and furious. There are still normal people out there that appreciate a lexus and want it's safety features and options. Drive it like a human, own it like a lexus owner, treat it like a lexus........
many reasons, many reasons.
The TC works by both pulling back the throttle when wheel slippage is detected, and also by applying the ABS brakes to the one spinning wheel to bring it's rotation back in line with the rest.
Anyway, installing it in your car would be a hassle. Besides the ECU and console parts that you mentioned, you'd also need the special throttle body with the sub throttle valve, a TC master cylinder, a TRAC accumulator, plus the TRAC pump, the ABS actuator and TRAC brake actuator, and all the associated plumbing and wiring, including the wiring going to the left and right rear wheel speed sensors and throttle position sensor.
The Lexus repair manual devotes dozens of pages just to the traction control system, it's not a simple piece.
-=Photon=-
i drive my car in chicago/dekalb winter. i have no trac from the factory and love it. the old lexus trac system was in such early stages of its development when installed on our car that it is actually a detriment. the system will only work right with factory sized wheels or stock differential gearing. anything that is replaced that may cause a discrepancy in the vehicle speed and actual wheels speeds will cause the trac to take over either too soon or too late. both can be dangerous. my buddy has a 95 sc300 AT with trac and his car is horrible in heavy rain or snow. my car on the other hand gets up and goes. the trac install would be a hassle and not worth it at all. i dont have trac and i also disabled ABS. it was a nuisance when i went drifting so i turned it off. i liked the braking better without it turned also. i just pulled the ABS solenoid and pump relays from the small fuse box on the drivers side by the master cylinder. i have had the ABS light on but it doesnt bother me.
