Please help before I drive my FI SC400 into a lake and leave it for dead!
#31
Lextreme, paulwd,
I have to disagree on it having anything to do with not having a bypass valve. I have not had one for quite awhile, way before this problem started.
cOwboy. I need some tuning, no doubt, but I really don't think it has to do with my current problem. There was a time where I was running with just the ECU and the MAF, I was seeing 11.5 to 1 with up to 6psi.
I may have found my problem. See next couple of posts.
KC
KC
#32
Why you should never, ever spray into a KV MAF.
Ok, I think I may have found my problem. And in the next couple of posts I goning to show you. Also, I really have no idea how a KV MAF works, but I have some theories, and if I'm correct, I can see why I'm going lean.
Pictured below is the inside of the Lexus KV MAF. If you notice, there is a lot of sealer inside of it. I think that the two parts (no idea what they should be called) in the middle, towards the bottom are the sensing elements, whatever they may consist of. These elements appear to be connected to each other in a V shape and they are directly above the shaft that sticks down into the air stream.
#35
Somehow, the vorticies, or the pressure created by them, makes its way up the two holes, one on each side of the shaft.
Well, if the sealer on the inside of the MAF is leaking, the pressure created in the sensing elements would, of course, be less than it should be. This in turn, would not allow the mirror, or whatever the heck is in there that creates the frequency that the ECU sees, to do its job properly. Lost pressure = less vibration = lower frequency = lean.
In my case, I think the cause of sealer failure was spraying brake cleaner into the MAF in attempt to clean it. This is OK to do on a hot wire MAF, but brake cleaner will eat sealer.
Thankfully, I have a MAF on the way and should know for sure soon.
#36
If anyone else has ever had one of these apart, please enlighten me. I do think that it could be taken completly apart and resealed, I just can't figure it out.
Maybe I could take it to an electronics repair shop.
In the meantime, I'm going to set the MAFTPro for speed density. I actually unplugged the MAF today with the Pro set to SD and it drove quite a bit better. Still lean with boost, but it always has been, one of the reasons I don't use the Pro in SD. I need to make some logs for TurboBob over at maftpro.com, I'm sure he could fix the MAF / MAP curve for me.
KC
KC
#37
Moving SC Threads
My .02 & clarification on other operation statements.
Cold engine start up 'open loop' the computer uses preset fuel maps.
Adjusts using airflow/ map, coolant temp, air temp, O2 & predeterminded
amount of run time.
'closed loop' begins when O2's are fully heated up. The computer uses O2
readings as it's #1 source for A/F adjustments when warmed up. (not
as described is previous post)
The AEM wideband I beleave auto calibrates w/ every ignition cycle.
(doesn't mean the sensor can't be bad)
I know you have been running w/o 1 upsteam O2 sensor, but it's still a
bad idea. The computer needs both functioning for comparison. If missing/
faulty the computer substitutes a safe value. This would lead to tuning
issues. (weld in another bung of the wideband)
Overall your describing a hot soak issue. Maybe put the intercooler back on
& see. Possibles: MAF/IAT, CTS - coolant temp sensor or leaking injector
when off - rich start up. Although the injector thing would clear up after
a few minutes of running.
Also, after any 'change' you make I would reset the computer & test drive.
The computer is slow to readjust after a change. You may have 'fixed' it
w/o realizing, then put back & moved on.
And yes spraying any sensor directly is a bad idea. I clean Hot wires w/
spray on a pipe cleaner, not sprayed directly. Altough yours is a carmen
style & should not be cleaned as you can see.
amount of run time.
#38
amount of run time.
amount of run time.
KC
#39
Not to be a butt here, but EVERYONE seems to be missing the fact that the lean issue STARTED ALL OF A SUDDEN. I have had this blower on the car for months now and have never had the car go lean beyond being able to compensate for it before. I have run before without my fuel computer and was seeing 11.5 to 1 with up to 6psi. Now, I don't even make it to boost, and I'm going lean. Something has failed. I'm hoping its the MAF. I should know in a couple of days.
Like night and day honestly. This actually started happening after I made the most recent videos. Was fine when I was making them, seemed a little lean on the way home, and the next day when I drove it, I couldn't give the engine any throttle without going lean.
KC
KC
#41
I had a member send me a spare MAF, helped a little, who knows if the lent MAF is really any better though. It does seem to be a little better runing in SD.
I also figured out that the EGR block off gasket I had made failed on both the intake and exhaust sides. Made a temp block off plate. Bought some stuff at Lowe's to make a permenant one. Considering blocking off / removing the EGR pipe just for temperature reasons.
Replaced the engine coolant temp sensor. This has seemed to help a bit, but it's still not right.
Have a few things I'm going to check this weekend. I might possibly install the 315's I have.
I think that's it for now.
KC
#43
I don't think I have a vac leak, although who knows. When I was having trouble with leaks in the past, I would run lean at idle / cruise and rich with boost. Makes sense when you think about it. Under conditions of vacuum, unmetered air would be pulled in, causing leaness. With boost, metered air is escaping, causing richness.
I may be on to something on the whole hot / cold AFR thing. Check it out here. http://www.fullthrottletech.com/show...?t=3690&page=7
KC
#44
I have been told that you can use a smoke machine to find vac leaks, not sure how it works yet, but will find out more about it if you want me to.
I am sure you will solve the problem soon KC.
#45
I have found all my leaks this way. The only problem is that it's hard to into some places where there could be a leak. I may try the EVAP smoke machine I have at work, one of these days.
KC
