2Jz Ge Best bang for the Buck?!
Hey I currently own a stock Engine wise 97 Auto (kinda wish was manual but hear autos good if I where to turbo cuts down on turbo lag.) Sc300 with 80k miles with the 2jz Ge, and was wondering what the best bang for my buck would be performance wise I now not to many keep the 2jz ge, and end up swapping with the 1jz and Gte is it practical to get some nice performance outa my Ge?? Should I NA-T, TT or one nice Single Turbo not looking to swap Engines but might because just a spark plug job was ridiculous, lol I couldn't imagine anything half serious lol.
Btw, the spark plug job isn't as bad as you'd think. I thought I'd have to take the intake mani off to replace the plugs but I was able to remove just the throttle body to complete the job. The whole ordeal took about an hour.
Kruso
Kruso
Yea I figure was doing a little research to see the potential in turboing the 2jz-ge. What ever I decide to do, I will definitely not be doing an engine swap seems stupid to swap a perfectly good engine.... and im not looking to make a race car, although the 2jz Ge is a pain to work on...just changing spark plugs proved quit annoying.
With an engine with that low of mileage definitely go NA-T. Check out www.clubna-t.com . Questions that you may have about going NA-T can be answered here simply by searching or posting a question. It is amazing how much I have learned over the years simply by reading and posting questions here on Club Lexus and on Club NA-T. Good luck!
Check out the XS Power kit on Club NA-T. Some people may have negative things to say about it but many many people are using this kit and have experienced no problems, including myself. The kit is $1299 and you will be easily making 300rwhp without a problem on low boost. Mark (XS Power employee) is a great guy, and will answer any questions you have, plus I am almost positive that everything comes with a warranty. He has made great efforts (and succeeded) in the NA-T community to provide quality parts at a low price.
on a low to med milage ge motor thats been taken care of 425-480 is easy to reach and very safe if done right
my car is a 97 coverted to r154 5 sp and puts down about 470rwhp at 18psi witha/f steady at 11.3
parts used
2.5 mm boostlogic headgasket brings compression down to about 8.3 to 1
550 injectors more then enough for this power level
t67dbb with a back housing of .68 a/r
44mm tiaL wastegate with 12lb spring
tial 50mm blow off valve
map ecu v3 for fuel control
precison 3 row intercooler
parts listed is all it takes i can get 500 rwhp at 19 psi if i lean out closer to 12 but i decided to stay rich in case of spike or creep 470 is enough to kick ****
parts used
parts used
parts used
dustinleeh
Performance & Maintenance
22
01-27-12 11:23 PM
Shadowen
27
10-05-10 01:32 PM
