Power steering line fix..oh so pretty
Old 07-10-11, 11:40 AM
  #46
soarer479
soarer479's Avatar
any one have any good tips for getting this blue line into the end casing on the fitting? I'm having a hard time with it i can get it the first little bit in until it hits the threads on the inside and its just way to small i cant seem to get the threads to go around the outside of the line and catch. I've tried trimming down small amounts of the blue outer weave but still a no go. To give you an idea ive had this thing in a vice and a socket around the fitting pressing down with all my weight i just cant get it on.
Old 07-10-11, 12:33 PM
  #47
sc4doubleO
sc4doubleO's Avatar
Video shows how to assemble the fittings
http://youtu.be/8LovY7kedyE
Old 04-02-12, 10:45 PM
  #48
SC300_704
SC300_704's Avatar
bumping a old thread..anyone knows if one foot of the power steering hose is enough? found this site that sells it cheaper than summit and jegs btw http://www.anplumbing.com .
Old 04-02-12, 11:08 PM
  #49
ecuajyls
ecuajyls's Avatar
niceeeeeeeeeeeeeee i love to fix my car for cheap
Old 02-12-13, 08:00 PM
  #50
jwin
jwin's Avatar
Nice video
Old 03-21-13, 09:25 AM
  #51
Dms3603
Dms3603's Avatar
So quick question, couldn't the earl fitting bottoming out problem be solved by using a shorter fitting like a 10mm-14mm?
Old 08-30-13, 08:55 PM
  #52
jwin
jwin's Avatar
i am going to try to get a hose made at autozone where they have it already crimped.
Old 10-13-13, 11:52 PM
  #53
Cleanshots
Cleanshots's Avatar
sorry to bump this but to help the bottoming out adapter in the rack problem.. this fitting is not as tall..
http://www.summitracing.com/parts/rus-670530/overview/
and also this is a banjo style adaptor...
http://www.summitracing.com/parts/uis-8021560/overview/
ill be doing is very soon and re-routing my low pressure line also, and probably install a small cooler.
Old 03-20-14, 08:44 AM
  #54
SCereal
SCereal's Avatar
Bumping this old thread for some questions since I need to replace my high pressure hose and will need to add a cooler. Might as well replace it all. Can someone comment on my proposed setup?
Reservoir to pump, -10AN (using PHR slim fit relocation kit)
pump to rack (high pressure) -6AN with the fittings described in this thread and appropriate line
rack return to cooler -6AN - DM has a return fitting that's supposed to work since its an odd size like 17mm
cooler to reservoir -6AN
The only link i need the 3000psi line on is the pump to rack, correct? the rest standard stainless braid will work?
Old 03-27-17, 01:32 AM
  #55
MDNT_DRV
MDNT_DRV's Avatar
BUMP for an answer to this?
Old 03-27-17, 02:13 AM
  #56
MDNT_DRV
MDNT_DRV's Avatar
also, where are you guys getting your copper crush washers? directly from toyota? do you have a part number? i can't find a proper diagram anywhere. if aftermarket, what size do we need to purchase?
LEXXIUM (01-14-19)
Old 05-06-20, 10:54 PM
  #57
punch718
4th Gear
punch718's Avatar
the fittings I use came with a flat washer and oring
Old 05-08-20, 06:20 PM
  #58
BeigeSC300
BeigeSC300's Avatar
I would be suspect of a flat washer and o-ring holding up at 1400 psi. This gates hose worked for me, perfect fit and hoses clocked perfect. Sometimes you can get them at a good price slightly under $300
mikek753
08-18-20 08:07 PM
91LS400LEX
42
03-14-15 01:47 PM
Tament
03-21-13 12:28 PM
yihaw
06-09-11 02:49 PM
BROOKLINE
RX - 1st Gen (1999-2003)
03-08-11 02:40 PM
Quick Reply: Power steering line fix..oh so pretty
