Will the BL built TT auto trans fit in an SC?
Old 08-14-08 | 04:08 PM
lexhere27's Avatar
lexhere27
I know it's an old thread, but I was curious if using the TT auto is possible on the SC400s 92-97. I heard the TT has slightly different gearing along with different internals (clutch packs and such).
Thanks a lot.
Alex
Old 02-24-09 | 01:46 AM
lexhere27's Avatar
lexhere27
bump for more info
Old 04-29-09 | 12:31 AM
Methodical's Avatar
Methodical
It fits, no problemo
Old 04-29-09 | 05:48 AM
Mr.NA_T's Avatar
Mr.NA_T
Old 08-08-09 | 10:05 PM
sleeperSC's Avatar
sleeperSC
I have a sc300 with 1jz auto swap. I would like to know if a build surpa TT trans will work?
is the cable vs electronic thing an issue?
also If I ordered the BL supra na-t trans would the wiring and everything hook up to the 1jz harness without issue?
there is lots of misinfo about soarer auto transmissions on here and supraforums. I have done the searching and come up with lots of different info and tons of threads with people saying "search"... but not giving any info.
After 2 hours of searching I figured Id ask.
Thanks.
Old 08-16-09 | 07:27 PM
SuperiorSC's Avatar
SuperiorSC
Thanks.
the TT trans will not work..... unless you are using a standalone that can control the trans such as AEM. you already have the 1j trans just add some coolers and shim it and you should be fine(depending on how much power you are making) gl hope this helps out
2jttz
11-23-12 05:17 PM
mikexsc3
11-14-12 04:03 PM
forcefed86
10-27-08 11:50 AM
