SC400 Oil Change ... What a Breeze!
I just completed a complete oil/filter change on my new SC400. The previous owner told me that it was due ... so I did it. Except for the fact that you have to remove approximately 15 bolts to remove the plastic engine shield underneath the engine it was a breeze. The filter is nice and convenient to remove too.
Some things I found interesting:
- My hydraulic jack lacked the required clearance under the engine bay to lift the car so get this ... I jacked up the car using both rear-side points. This raised the car enough for me to get my jack stands (with wood inserts) under the front jack points. Then I lowered the jack and proceeded to the other side.
- I added 5 quarts of Syntec and found that there was enough room to (probably) add another half-quart. My manual states that the oil capacity of this engine is 5.1 US quarts, with a filter change. Interesting.
Does anyone know of the recommended oil/filter change schedule when using synthetic (or partially synthetic) oil. Is it 5, 6 or 7,000 miles? How many months if you don't drive that much?
-Have all the seals been replaced recently or at all for that matter? And has there been conventional oil in there all the time before or synthetic? If you just decided to switch from dino oil to synthetic you might want to rethink that as seals might start going bad or blow a gasket from deterioration. Please correct me if I am wrong.
Full synthetic is somewhere around 10k but most people don't trust it that long no matter how good it is. Still do another oil change in 3k miles to see if there is any buildup of gunk if it was just swtiched over between the oils.
I've actually been searching threads the passed few weeks because I plan on changing my own oil but can't seem to figure out whether my engine is using conventional or synthetic oil... I would assume conventional but not certain. Also wondering which brand of oil to go with since there are so many to choose from and different ones recommended by people. Also, I've read to have one side higher/lower than the other for the oil to drain better.
I did about 8k or so last time before a change. The oil wasn't that much darker than when I first put it in. Needless to say, its good . *NOTE (I also drive my car for the most part very very gently, so I hardly put any pressure on it).
I've actually been searching threads the passed few weeks because I plan on changing my own oil but can't seem to figure out which brand of oil to go with... since there are so many to choose from and different ones recommended by people. Also, I've read to have one side higher/lower than the other for the oil to drain better.
I got a great "combo" deal at Autozone. I picked up 5 quarts of Syntec and a Mobil1 premium filter for $26. Got to their website, look for their sales flyer, type in your ZIP code and you can view their specials.
i'm going to do a oil change in about 1,000 miles more. picked up my car at like 111,000 miles and i'm at about 112,000 miles now. and my mechanic said the oil looked pretty good still at the time. so gonna switch to mobil 1 and just have to find a filter later. K&N or Mobil 1, which ever i can find.
anyways...is the oil filter itself under the car too? cuz i can't see it from the top and i've never went under it yet.
Peace out
Peace out
I normally use Mobil 1 and i run it for 5-7k miles but Im trying Quaker State Syn that I got for 2 for 1 awhile ago. Probably wont make a difference, but I will run this somewhere between 3-5K miles.
im a Royal Purple fan but I will try Amosil this time. But I think this car has coventional oil. So what i do/will do is go to synthetic blend first check for leaks and next oil change then go to full synthetic. I was told that is a good way to switvh to full synthetic without damaging seals etc.
Peace out
Peace out
The filter is very near the center bottom of the engine, facing right (when you are under the car). It sits horizontally and is very easy to get to ... especially if you have a tight filter.
