3 inch Straight pipe Exaust
Old 03-18-08, 01:36 PM
Turbo?
Turbo?'s Avatar
Default 3 inch Straight pipe Exaust
Well well, i was at Midas today to get a quote on a custom exaust work.. and they are refusing to do work on the car... Because i want to eliminate the Catilistic converter, they are saying quote " that the car wont run as well, and it'll throw the idle off" is that true?
if so what should i do, i want to run a bigger down pipe atleast a 3,1/2 inch, then 3 inch downpipe back straight pipe exaust, is it doable, and if so where do i put the O2 sensor?
Old 03-18-08, 01:57 PM
Bean
Bean's Avatar
What car? There's no info here for anyone to help you with
Old 03-18-08, 01:59 PM
Turbo?
Turbo?'s Avatar
Soarer! 92
Old 03-18-08, 02:17 PM
turbodremz
turbodremz's Avatar
factory turbo? you can run straight off the dp with out problems...
Old 03-18-08, 02:20 PM
Turbo?
Turbo?'s Avatar
what about the O2 sensor?
Old 03-18-08, 02:21 PM
Turbo?
Turbo?'s Avatar
and yes they are factory turbos what about the cat, can i Eliminate it?
Old 03-18-08, 02:26 PM
stevechumo
stevechumo's Avatar
Of course you can eliminate the cat. It'll be a lot noisier. You should have the O2 sensors connected as though the cat is there.
Old 03-18-08, 02:31 PM
Turbo?
Turbo?'s Avatar
ah ok cool dealio!
thanks guys!
Cronus1995
Performance
03-29-19 11:57 AM
Dingusthe
RX - 1st Gen (1999-2003)
02-05-18 04:25 PM
387
01-09-17 07:46 PM
jdub20tx
SC- 1st Gen (1992-2000)
07-09-11 10:01 AM
lexforlife
SC400 / 300 Classifieds
10-31-08 09:20 AM
Quick Reply: 3 inch Straight pipe Exaust
